Xiaomi Mi MIX 2S
Hafi
If it's me, I will choose the MIX 2S. :o
The MIX series is Xiaomi's premium flagship lineup afterall, and it has extra feature that the Mi 8 doesn't have such as wireless charging, which is good to have(some may disagree:o).
yea I would choose Mix2s over Mi8 just for this wireless charging feature but since Mix3 is rumored to be out in Sept, I am prepared to wait for Mix3 instead.
yakman
If mix3 came out before Feb 2019, it would be still based on the same SoC platform.
The best scenario major changes would be
bigger battery
in-screen finger print
pop-up front cam
dual GPS
OLED screen
Buy now Mix 2s and upgrade later to Mix 3s or Mix 4 would be my choice
dest86
i am currently a p20 pro user. understand right now in terms of low light camera p20pro wins ? i am thinking to get mimix2s, isit a bad move or should i stay wif p20 pro?
cscs3
P20 pro is quite expensive, must well get Samsung s9+.
Xiaomi Mi Mix 2s is much cheaper with good CPU choice.
yakman
p20 pro still wins on low light against both MIX 2s and S9+.
but other areas including day time cam debatable at least.
dest86
thanks for the fast reply. will it be a bad idea to get rid of p20 pro and get a mimix2s ?or should i get mi 8 ?
garychengjw
There's no right or wrong move getting rid of it. It's depend your needs.
Sent from The OG Google PIXEL XL using GAGT
cscs3
Agreed it win Mix 2s. May be s9, but not s9+ for sure. As tested ot side by side at telco store before.
cscs3
If all you need is a phone plus general photography. Mi Mix 2s is good enough. Mi 8 not in Singapore yet. Base on Hong Kong price. Mi 8 is slightly cheaper thenix 2s.
Not to forget this 2 phones come with standard QC charging standard. Huawei don't.
Not to forget Mix 2s also come with fast wireless charging. Which Mix 2 does not have.
skai_11
by the way, do you guys have any issues with the camera at the bottom?
how to take selfie when our palm covers the bottom right corner usually?
elementz
That's what I did. Kinda regretted cos the camera is really far behind p20 pro. Night shots cmi de.
But general usage of the phone is better. Smoother. Built is also better. So depends on what u need.
Sent from Xiaomi MI MIX 2S using GAGT
garychengjw
Back to Mix2s. Loving the big screen :)
Sent from Xiaomi Mi Mix 2S using GAGT
cscs3
Yes, position is funny. Only if you rotate the phone upside down, then it looks ok!
