looking to see if can or not too. there is no option to change the record path in the app. mijia 360 1080p i just got it to record to my NAS.Xiaofang can upload to NAS?
Is xiaoyi 1080p video quality comparable to mijia 1080p? or better?
Recently my xiao fang's sd card also not working / cannot be formatted. Last time when it detect with no sd card, I was still able to format with PC. Is the camera killing the sd card ? Gosh, i have only used the camera for 1 month, how many SD i am going to buy for this! i already using dynamic recording..try with seagate nas and synology, both work.
what is the brand and capacity of your micro sd?
My xiaomi yi 1080p (which only accept 32 gb max) kill a few of my micro sd card. sometimes format help
Anyone using mijia 1080p? If the sd card full, Will it override the earlier recordings?
I'm already actually using Mihome for my Dafang
Still have that annoying QR code problem when setting up.
of course la![]()
My Dafang is working well, Xiaofang, I still wait for 1 to 1 exchange. Comment after testing it again.
Some of my camera goes missing mysteriously and after awhile( quite long) then reappear again in mi home app... Anyone having same experience?
Have the both old and new version, yes will override for old versionAnyone using mijia 1080p? If the sd card full, Will it override the earlier recordings?
same here.
I have the 3 xiaomi Ip 720 and 2 pc of Dafang.
All my 3 pieces of 720 camera all disappear for few days.
I almost want to upgrade all to dafang.![]()
i have the same issue few month back........bought a cheap card reader (description below) to put it on the microsd card
bought 2 card reader and found out that it burn both of it![]()
i think it is because the cam already so hot and heat transfer to the card reader and burn it....maybe i wrong tho
i found out that i solve this issue after i started to use card reader adapter and never had this problem anymore until now(description as below)
only problem it look messy coz u can see the wire of the adapter back of the cam![]()
so far so good now and im using 32gb max size microsd card for the recording
Can xiaofang recording be pointed to a Nas?
Did you guys buy from xiaomi Singapore or order from Taobao?
I'm thinking of getting this, but I read from the taobao group, some of them said cannot connect, not sure user problem or locale restriction.
https://detail.tmall.com/item.htm?spm=a230r.1.0.0.1ad0e18aYaAueH&id=572524643298&ns=1
