[IP Cam] Xiaomi IP Camera Xiaoyi
Agent_X
Anyone has a guide on how to connect Dafang to NAS? I still can't figure it out.
cy2000k
try with seagate nas and synology, both work.
what is the brand and capacity of your micro sd?
My xiaomi yi 1080p (which only accept 32 gb max) kill a few of my micro sd card. sometimes format help
Recently my xiao fang's sd card also not working / cannot be formatted. Last time when it detect with no sd card, I was still able to format with PC. Is the camera killing the sd card ? Gosh, i have only used the camera for 1 month, how many SD i am going to buy for this! i already using dynamic recording..
LoneTraveller
I'm already actually using Mihome for my Dafang :(
Still have that annoying QR code problem when setting up.
This is how i setup my mijia 360 ipcam. Hope it is applicable to you.
1. Download the mihome app from google play store and do not update the app at all costs.
2.Reset the cam by pressing the back reset button for 5 seconds to clear your previous failed installation. The cam will say in mandarin that it is resetting.
3. Use bluetooth to setup cam instead of using the phone to scan the qr code on the back of the camera.
4. Follow instructions on the app.
5.the app will eventually generate a qr code on the phone which you will then let the camera "see".
6.cam will then say setup successful in mandarin and the app will show your cam in it.
7.you can then choose the cam in the app to view the images or video.
plmokn
Some of my camera goes missing mysteriously and after awhile( quite long) then reappear again in mi home app... Anyone having same experience?
xtractor
i have the same issue few month back........bought a cheap card reader (description below) to put it on the microsd card
bought 2 card reader and found out that it burn both of it
i think it is because the cam already so hot and heat transfer to the card reader and burn it....maybe i wrong tho:s13:
i found out that i solve this issue after i started to use card reader adapter and never had this problem anymore until now(description as below)
only problem it look messy coz u can see the wire of the adapter back of the cam
so far so good now and im using 32gb max size microsd card for the recording
shark78
same here.
I have the 3 xiaomi Ip 720 and 2 pc of Dafang.
All my 3 pieces of 720 camera all disappear for few days.
I almost want to upgrade all to dafang. :s13:
plmokn
same here.
doesnt seems right... i encounter twice already
ipaq4444
Can xiaofang recording be pointed to a Nas?
