Qoo10 Deals. (Strictly no referral link) - Part 5
shadow84
Can Qoo10 cancel order like Lazada? Lazada cancellation quite easy and straightforward.
Sellers in qoo10 can cancel your orders at their end but will kena a penalty. Most will ask you to ownself cancel if you not happy with your order. They wun kena penalty but u wun get back ur cart coupons.
aKaGiz
What penalty sellers get?
shadow84
Im not sure as im not a seller, i can assume higher commission since they go by points system. The higher the points, the lower the commission, something like that?
A penalty would most probably be a reduction in their points.
lazybee
Never cancel yourself. This is because the cart coupon will be prorated for the remaining items. Qpoints might not be prorated though.
I have verified this on previous purchases.
It is a different case if you cancel instead (would rather cancel all items if they have not shipped).
shadow84
Lol, you are contradicting yourself?
lazybee
Never cancel yourself when seller ask you to cancel. My answer is reference to where seller "force" you to cancel. They should bear the penalty. Write to qoo10 to cancel for you if seller do not want to cancel.
You can cancel yourself definitely only if none of your items are shipped. But qmoney get returned first. If some of your items are shipped, you pay the full amount.
Gametaku
Those thinking to get Amazfit bip from qoo10 earlier..can get from Shopee flash deal now. Price is 76.99. If you collected the coupon earlier..then you can get it at 66.99. Alternatively, you can checkout with Citibank SMRT card to get it at the same price.
Shutterfly
Thanks for the lobang. Will go check it out.. Need to sign up for shopee account first.
Shutterfly
How to get the discount to $66.99 using the Citibank smrt card?
wongminmin
New to Shopee customers enjoy S$10 off with min. spend of S$20, use Promo Code: CITISMRTNEW
All Shopee customers enjoy S$10 off with min. spend of S$70, use Promo Code: CITISMRT
Shutterfly
Thanks a lot, bro.. First time using Shopee.. Most of the time on Qoo10, a few times on Lazada.. Seems like Shopee also not bad.
Gametaku
Thanks wongminmin. Forgot to quote the code :s13:. So for Shutterfly case, buy something else that is $20 and use the 10 off 20 first before using the 10 off 70 on the amazfit bip.
Shutterfly
Good idea but I can't think of anything to buy now.. Haha.. Scared the deal will be gone soon..
Shutterfly
Damn.. realised my SMRT card no longer active.. Now can only make do with the DBS discount of $7. :(
