Xiaomi Pocophone F1
Just Me
u bought from shopee... we bought from qoo... we paid abt 405 after GC and 8% off coupon..
They removed the listing from qoo10? Can't find the F1 from mi premium store
FinalTidus
Wah sian, shouldn't have topped up $40 :(!
I topped up 40 also.
But I think they know Shopee has less vouchers than Qoo10 hence got difference.
Anyway no regrets topping up. :) I feel that extra 64GB will pay off as I intend to use the phone for the next 2-3 years.
windwaver
How many top up? If 128gb only blue I dun want.. Anyway I saw export set 128gb at $398..
Newstar huh? For $100, I think that's the bare minimum for an export set. That means if people buy with less than $100 difference, just get the local official version.
$499 from MI store easily get discount to about $450, $398 still not good enough. Some batches of Xiaomi phones seem to have bad batteries which is covered by local warranty.
Kousoku
How do u set up battery percentage on pocophone?
I think cannot set yet, find every setting still cannot find battery percentage. I can't even set/see any app notifications on the status bar, that one clock on the left side of the status bar just took up all the spaces.
windwaver
Shoppee top up $20 cheaper than Qoo10?
Nakedtoes
think need to install apps for the batt percentage... i need that funciton sia...
Nakedtoes
i use so many xiaomi phones and bought for relatives and friend ok got only 1 case redmi note 2 the battery bloated.. but the battery can be change... and i suspect is because my that friend always like to use cheapo china adapter and cable thus bloated.. all my charger and cable all branded good one..
amazingone
PiGuDong
unfair lor... but in shopee the most i can bring down is to 424 max
Qoo10 I brought it down to paying about $405 (gift cards + 8%), after topup it became $445.
Shopee if you bring it down to $424 (no idea how you bring it down) , after topup will become $444....
Verdict:
- If buy 64gb, its about $19 cheaper in Qoo10
- If buying 128gb, shopee is cheaper by $1
windwaver
Agree. I also bought a lot for family (5 phones) and only 1 has a battery problem after a year (warranty over anyway).
