stupidog
- Feb 15, 2005
Don't talk about water,even dust also cannot keep out
if there's sliding feature in mix 3...
i think mix 2s will be the last best design of bezeless phone.
The sliding design quite turn off. It's like back to the 90s phone? A small teardrop notch like the essential phone would be a good compromised imo.. then need work on notifications part, some info like battery percentage is high priority that needs to be shown at all times. Most people will hate to drop the notification bar just to check the battery imo. Other icons like apps can be lower priority and if allows for customizable multi color led for apps will be best
probably something ripped off of this design.
More than just upgrades. It's more of jumping into another bandwagon. But u need to ditch mircosd slot if u are using.Ask u all. If I am currently using only a Redmi Note 4, is Mi Mix 2s a considerable upgrade? I have been using the note series mainly because affordable, but the mtk heating issue has been a headache.
Sent from Xiaomi REDMI NOTE 4 using GAGT
It's like upgrading from Toyota altis to a GTR!
No lah, gtr is more like pocophone
Mm2s is like a Ferrari.. fast but with style too![]()
May be that also means you cannot flash to other OEM firmware?
Bros who are hooting the China Xiaomi phones like the green mix2s. Take note :
Xiaomi no longer supports loading of global rom on China sets and vice versa
http://en.miui.com/thread-3831680-1-1.html
what is the price for Mi Mix 2s is spore ?
Mix 2S 128GB still hover at around $700+ range Sia...
