Viewqwest security issue and horrible service
Trans-Am
But as OP said VQ would change the IP to a wrong one, so how do you know which is the correct IP we should have?
I believe when the technician first came to your house for installation, they got write down the ip address.
If not email their cso
Sent from :bandit:
Stay low Move fast !
Shoot first Die last !
One shot One kill !
No luck Pure skill !!
:s17: using GAGT
DriftKing
Sent from :bandit:
One shot One kill !
:s17: using GAGT
Thanks! I've relocated so not sure if the IP stays the same also..
sadboy
IP address will change as Long as you you on another exchange.
Last time I moved fr north to west IP address change because they say diff
Exchange IP address allocation diff.
civicguy
I am on M1. Only downside compared to viewquest is the lack of free static IP. But with M1 you get a IPv6 address as well.
Myrepublic use CGNAT so it's a instant no for me.
Starhub got some small issue with their DNS and ipv6 reliability.
Singtel will lock you into their ONR.
Whizcomms is basically Singtel without the lockdown ONR.
I am quite technically noob.
I am going to leave VQ too.
For M1, why is the lack of a static IP important ? For getting back to the house network from outside, is it ? I currently use DNSDYN to do so. Is that a solution ?
AC2
M1 got static IP just need to pay 2 buck monthly i think. I switched over to M1 from VQ. Best decision ever haha.
dryteletubby
A DDNS like DynDNS should work. Unless you are hosting web content on your network then you should get a static IP address
flyingco
Actually, I have been on viewqwest some time and honestly, I don't see what the service problems are which everyone seems to be complaining about.
I mean, they answer the phone way faster than starhub did ages ago and they don't have mega long downtime, which I have experience with starhub before.
I used to trade and it was really crap when starhub went down, while with Viewqwest, I have not gotten caught with my pants exposed.
Just my two cents worth.
sadboy
You dig a 2018 post which was case close just to say ViewQwest is good and Starhub put your on hold?
The customer base is different. Starhub might have 2-5 times customer then ViewQwest.
Henry Ng
For home use internet, i think all ISP also do not have security protection. User can get their router with security protection or/and use DNS with some protection. User can also install security software on their devices. Log in with standard local user on your Windows computer and not as administrator.
