maur_james
- Dec 6, 2011
2yrs 3mths
He did reset the mains after topping up, waited for 10mins, still no cold air or the sound of 'rushing gas' you hear when you turn on aircon.
I guess, I have to LLST and get a new unit. Thanks!
I think I called them, warranty is 2yrs, maybe I should call them again.Should be under compressor warranty still.
I didn't purchase extended warranty.One more thing. My apologies for missing this out. You might want to check if you have purchased extended warranty. 2 years+ is rather premature for the system to give way in so many parts. Not that it is not possible but sometimes really quite unfortunate. If extended warranty is purchased, it might not cover the piping work but the system should be covered. One last resort if still in doubt with the initial diagnosis will be to consider having Mitsubishi come for a check but it should be chargeable if not under warranty.
Hi... need assistance ...
Fujitsu aircon.
2 units with 5red,7green. And 1 unit with 2 green.
how?
But like this what good does it do for the scammer?The promoter who goes by the number 91892893 is a scammer. They issue an appointment card with serial number under the heading No.1 aircon service managed by xi run electrical supply which is actually in Johor. I waited for them to come at 1pm to service my aircon but did not turn up and when i contacted the promoter he kept saying they will contact me. Please do not fall for this free trial scam. They are a bunch of scammers.
how come condenser PCB spoilt must change whole system ??
Hi maxicooljason bro, can pm a quote for Panasonic system 4 general servicing?
Thanks.
Hey you can try a quote from Mr Yap @ 90291655.
I think their price is very reasonable been using them for last 3 years
the aircon in my room could not be switch off and on by remote control. the air continuously blowing out from the fcu. what could be the problem?
Maybe he/she has some great urge to post leh...die die must come create account to 'share' the good lobang.1 post and recommending liao.....
Ownself post ownself recommend ownself?
