Xperia XZ Premium - The successor to the Z5 Premium is finally here!
vofzxy
Wah.... This update changed many UI components...
Like the notifications... Now status bar shows the time.... Etc
Sent from Sony G8142 using GAGT
vofzxy
Hmmmm the slow mo video function hidden inside the Pie camera UI
Difficult to get to sia
hush66
I will suggest you to do a factory reset upon a major firmware upgrade then you will not have such battery issue. =:p
Fully agreed. That's why I'm holding off upgrading until the weekend when I have more time to do a fresh install.
yhw22
Anyone got smart backlight app kept crashing after updating to Pie? I already did factory reset still happen again.
The problem since like randomly appearing.
guile
I have that issue too. Damn irritating.
yhw22
Notice that the smart answer setting is gone too. Any advise?
omelet
Have you tried software repair via Xperia Companion instead of factory reset?
carlover76
Smart Call Handling Options is found under the following :
Phone Dial ->3 dots -> Settings -> Calling Accounts -> Line 1 or Line 2 -> Smart Call Handling
ranchy
Hi all, checking after the update, on the status bar, are you all able to see the Bluetooth icon at status bar?
I don't seem to have it after the update.
segafan
Interestingly, I still haven't seen any updates on my phone. /sad.
Am using the red colour design, hybrid SIM i think.
Telco is Starhub. Phone also from Starhub.
Really no idea why haven't received the update. Hmm.
yhw22
Hmmmm.. it since like not working properly.
