The startup of loading the widget is slow after upgrading to pie.
Sent from Sony G8142 using GAGT
Battery is not as good after updating to Pie as compared to Oreo....
I will suggest you to do a factory reset upon a major firmware upgrade then you will not have such battery issue.![]()
I have that issue too. Damn irritating.Anyone got smart backlight app kept crashing after updating to Pie? I already did factory reset still happen again.
The problem since like randomly appearing.
Notice that the smart answer setting is gone too. Any advise?
Thank.Smart Call Handling Options is found under the following :
Phone Dial ->3 dots -> Settings -> Calling Accounts -> Line 1 or Line 2 -> Smart Call Handling
Hmmmm.. it since like not working properly.Smart Call Handling Options is found under the following :
Til now only SingTel and customised SG.Interestingly, I still haven't seen any updates on my phone. /sad.
Am using the red colour design, hybrid SIM i think.
Telco is Starhub. Phone also from Starhub.
Really no idea why haven't received the update. Hmm.
