New rig introduction. Upgrade from intel 3770k
cochran
Hi
As my intel 3770k mobo is gone, i have to look to rebuild my rig.
I just need to get mobo, cpu, ram and upgrade my sata ssd to M2 sdd.
GPU currently is AMD RX480 8GB. Should be good enough. Not a gamer.
Looking at intel i9-9900k cpu.
Mobo i'm more toward Gigabyte (Service centre near me) or Asus (The brand)
I need about 8 sata port for my hdd. Which model mobo come with 8 sata port? most come with 6 ports only.
And can my thermalright heatsink for the CPU on LGA1155 able to use on the i9-9900k?
Thank you.
Koenig168
You can always get a PCIe SATA card rather than limit yourself to certain MBs with 8 or more SATA ports.
The Thermalright cooler will fit as the socket holes are the same. However, the i9-9900K runs really hot and a beefy AIO may be a better solution.
cochran
Just hope minimum extension card needed. If no good mobo with 8 SATA then have to go the extension card way.
And what AIO is the best now? My thermalright Venomous X with 2 x 120mm fan not good enough?
narkizy
Hi
Thank you.
Put it this way: the 9900k will melt it. Nothing short of a beefy AIO is enough to cool it. And why would you need something this expensive? Its more of a gaming cpu. If you need processing power and cores, go for the 2700x(also 8 core 16 threads) instead. Much cheaper, and about the same multicore performance.
Rashkae
9900k is for bleeding edge gamers with huge HSF / AIO.
For your needs, get a nice Ryzen. Consumes much less electricity too.
And the included Wraith RGB cooler is sexy.
singupingu
Also churn in to support you getting AMD Ryzen 7 2700X witb a decent Asus Strix X470-F.
Sent from OnePlus ONEPLUS A3003 using GAGT
gld998
Hi
Thank you.
Get ryzen if u dont game. Knn my xeon 10core 20 threads e5 2690v2 and gtx1080ti is to watch youtube now. Overkill. The extra money saved, get a bigger drive and consolidate your hdd.. i used to have 6x4tb drives, now 3x12tb drives. Get seagate iron wolf if u can.
Sent from Old Man Pressing For Retirement using GAGT
elmariachi
9700k with Gigabyte Aorus Ultra.
Runs like a charm and clocks to 5Ghz easy peasy. New Gigabyte BIOS is so much nicer and user friendly.
Meteor84
don't understand what is the logic here. you looking for a beast of a cpu, with entry grade GPU and only 16gb ram. what do you do with your com? :s11:
