Xiaomi Mi MIX 2S
vibranze
tempted to get the mix 2s
anyone able to share how long does the battery last ?
Me too, considering Mix 2s and Essential, can't decide which one to get. I like the Essential form factor more but it's last year spec compare to Mix 2s. Price wise Essential BNIB is selling for $400 (128GB version) and Mix 2s for $499 (64GB version). Did you manage to get one already?
Sent from OnePlus ONEPLUS A6003 using GAGT
wayne07
My screen cracked. Anyone know where can I replace? And how much? Any downtime?
Sent from Xiaomi MI MIX 2S using GAGT
Did you have a solution? I need to replace mine as well and the service center doesn't have on the spot repair service? Kind of regret buying xm now, didn't think of post purchase repair issue.
cscs3
Either DIY or send to SIM lim square. Not cheap if you factor in new phone price.
DIY can buy part from Taobao.
【伟玲屏幕适用于小米mix2 mix2s总成 触摸液晶一体屏 内外显示屏幕】https://m.tb.cn/h.3Kb7cqa?sm=db5580 点击链接,再选择浏览器咑閞;或復·制这段描述¥fEp4bMM54kZ¥后到👉淘♂寳♀👈
bbcccc
just updated to the latest 10.2.1
960p slow mo vids siol . . .
TheSnail
I can't see the battery % value anymore, way too small on grey or orange background. I changed to a Top Bar type to check.
Also, my alarm in the morning doesn't come with a notification, Lock Screen (Off/Snooze) Button or even an OFF function I can find. If I tap the blank screen or power button, it goes straight to Snooze.
kazuki666
Will 2s price drop because 3 releasing locally soon? :p
Sent from Xiaomi REDMI NOTE 4 using GAGT
kazuki666
I see the lowest is $499 for 64gb local warranty. This is currently good?
garychengjw
Doubt will drop more. Cheapest SD845 with nfc.
Sent from Xiaomi Mi MIX 3 ~Jade Green~ using GAGT
cscs3
So have to go to the shop. I did not see this price on any online store.
BTW, what is the 128G price?
128G is $599. Think with the new comer to run the Xiaomi store. They now have more products and price is quite reasonable unlike the pass. I would suggest to go to the store, inspect the phone b4 you take it home.
dyhyapp
Yeah..I am considering the Mix 2S. Currently I am using Pocophone but feel that I need the NFC, wireless charging and hopefully better camera pictures.
lousydrinker
Me too. Waiting for black 64gb to drop price
Posted from PCWX using ONEPLUS 5T
bbcccc
the looks of mix 2s reali shines compared to pocophone
nfcvn wireless charging is a plus point too
weeza77
You referring to which dealer?
