[OFFICIAL] TPG Telecom - Part 2
zilojian
Can share link for this ?
I bought this and it came in the mailbox today. Can store more than sim cards if experiment a bit and the case is very sturdy/shockproof
zilojian
Does your TP link mifi have WiFi band frequency selection ? Maybe default is 2.4ghz is slower . Need to change to 5ghz
hi, anyone knows if TP-Link M7200 mobile wifi can work with TPG 4G sim card? Did the APN settings as TPG told us to but still having speeds like 0.5mbps (at two different locations); tried with my friend’s one on the mifi same speeds. but when i insert into my iPhone XS it was reasonable like 15mbps
3xistence
not sure if this has been ask before. Is there any widget that can easily switch data usage between 2 sim?
kopi22
Just signed up for myself. Maybe shall pick up the SIM later in the afternoon.
bbcccc
this time round, where to collect the sim card?
cant find on website lei
Sent from Xiaomi MI MIX 2S using GAGT
kopi22
xiaozhi86
anyone know how to get volte on xiaomi mi mix 2? i try follow post 104 but those option not available on my phone plus when download the mtk app it say my phone not running on mediatek chipset? mine is running on snapdragon.
Thanks
lDuckRicel
Thanks
try this?
Disable VoLTE carrier check
*#*#86583#*#*
nasfieldjohn
once get confirmation mail after register means can go shaw centre level3 to collect sim card?
kalala
try this?
*#*#86583#*#*
Snapdragon just need key the above, enable VoLTE option and add APN:
APN: IMS
APN Type: ims,ia
VoLTE works instantly.. tested on Redmi Note 4, Mi Max 2, Redmi 5A all works magically so far
lDuckRicel
APN: IMS
APN Type: ims,ia
I didnt add in IMS, only TPG nia and it's work
using Mi 8 lite
ngbc
