Format laptop and reinstall windows 10
faded11
I am trying to format my laptop and reinstall windows 10.
Can i delete or format all of the Partitions?
If not which partitions should i keep?
Odessa
Yes you should delete all partitions. Then click "New" on the installer, it will re-create all the necessary partitions for you.
eric3743
Those partitions are standard OEM backup/recovery partitions.
If you are upgrade &or install newer Windows OS then those partitions are not much use anymore.
Let the new Windows OS to wipe clean & format accordingly.
If possible do go for SSD for faster performance on laptop as prices are dropping.
pikelocks
Yes. Just wipe everything clean if you want to install a new operating system. Those partitions are recovery partitions.
