Bieffe
- Sep 14, 2001
Since you have already paid so much and DrCool cannot solve your problem, I suggest you call Mitsubishi Electric itself. I reckon they sub-con out the jobs but since is recommended by Mitsubishi Electric I think they will less likely to con you.hi all.
i have a system 4 mitsubishi electric starmex inverter AC.
Recently the room aircon has loses its cooling effiency. My aircon is blowing cool air but it is not cooling the room to the temperature set.
I engaged Drcool aircon services and they recommend me to chemical wash the outdoor compressor unit on 07 Mar 2019. I went ahead to do it at $150. However it is still the same.
I did all 4 aircon unit chemical overhaul and chemical wash for outdoor compressor on 31 July 2018 for $580.
Today I texted DrCool again for advice and they say it is most likely valve issue and wants to charge me $350 for it without coming back to check.
May I seek some advice from you guys? I do not want to be wasting money doing unnecessary rectification as I have spend alot of money on this already.
Any good and reliable aircon servicing company to recommend?
How old is your AC?
Is the air flow strong at the FCU? What is your temp setttings?
What is the operating mode you are on? Hope is not auto.
Trying setting the temp to 20....air flow max. Turn on 1 unit only is it cold?
What they did usually will solve the problem. But since u said suddenly then maybe something else.
Was the FCU and condenser dirty when they chem washed it? If you have been servicing regularly then this chem cleaning is a con job.
Anyway what is paid to them u can't get it back....assuming is really expansion valve....more money need to go out....so why give to them? They ain't really solving your problem....so take your money elsewhere.....even if u have to pay alittle more your problem maybe solve by the new team.
