Wireless Adapter
firsttimerneedhelp
Hi guys my router isn’t in the same room as my PC and my house doesn’t have ethernet access points so i need to get a wireless adapter. What are the requirements for fast internet connection? it can be pcie or usb. I’m on a tight budget so the cheaper the better. Saw a few on lazada like 1200mbps for $15 but not sure if that’s true and stuff. Some insight would be good and maybe recommendations of particular models, thanks!
You using simi router?
How far is your room from the router?
My router is very good some linksys ac 5400 one. My room not far also, just that cannot use cable as can’t conceal.
Moi personally bought a 30 metre long Cat5e cable and pull it into my room.
Your case either grab a PCI-E or USB3 Wireless AC Adapter.
Lazada you need to check the model number.
China alot of mis advertising.
Darknights
those are theoretical speed limits... to add to that, it also depends on the speed of all antennas (400Mbps per antenna), combined. you'll need both ends to be using that many antennas to be hitting that speed.
https://www.forbes.com/sites/gordon...2-11n-wifi-whats-the-difference/#e78cc5839574
the above site gives a pretty good explanation of your wireless network speed nowadays.
Rashkae
Why not lay a nice LAN cable? I networked my whole flat
Psycovirus
Seems like a basic dongle. Not really good for a PC that is in another room.
I suggest you buy an Intel 9260ac PCIe card from Taobao. Around 125 Yuan. Shipping is 29 Yuan. Total about $35 SGD. Takes about 5-7 working days to reach SG.
Link to the adapter : 英特尔Intel 8265AC/9260AC 双频5G台式机PCI-E无线网卡/蓝牙5.0
Choose the 9265ac+8DB
If you don't know how to use Taobao, go with Aliexpress, Link to Adapter : WTXUP Wireless-AC 9260 9260NGW 802.11ac 1730Mbps Desktop PCI-e WiFi Adapter+Bluetooth 5.0 WLAN Network Card for Intel 9260ac - $40 - coupons. But the shipping can vary from 10 days to 24 days.
firsttimerneedhelp
firsttimerneedhelp
oo thanks will check it out. btw i have a 300Mpbs home plug thing lying around. I have no idea how to use it. Is it as simple as plugging it in and connecting an ethernet cable from it to my PC. and if so is 300Mbps fast enough for this?
jas1701
Which ISP router r u using now. If it is ST Aztech, better to change it before you get a USB wifi adaptor. ST replaced for me 3 times with the same model and still signal dropping. So in the end i got myself a TPLINK AC1900, no more issue.
Psycovirus
The model is Aztech WL559E
You will need 2x Power line adapter. One has to be plugged near the router and then connect the power line to the router with a LAN cable. Another powerline must be plugged near the PC. Then connect PC to Powerline adapter with another LAN cable. It uses your power lines at home to transfer data. I have had bad experiences with it. YMMV.
His Router is mentioned above to be Linksys EA9500 AC5400.
What he mentioned is a Power line adapter.
jskc3617
Mercury UD13H(水星ud13h).
This usb3 AC wireless adapter from TB not bad as I am using it.
firsttimerneedhelp
oo okay thank you. i heard it’s not a good solution too
