Snagged myself a Evpad 3 pro(2gb+16gb) from lazada. Listed price $169 but i paid around $95 after using up my remaining liveup credits and a $8 discount voucher. Its not local set but no matter since can use all the same.
Used the box for a couple of days and so far, cant say i am impressed. Firstly, lets start with the bad.
-Even with 2 gb ram, there is abit of sluggishness when navigating the evpad UI.
-Next, the 3 proprietary apps, Mars live/vod/catchup, takes 5-7 seconds just to startup and load into the app itself.
-Give you all the channels in the world also pointless if they dont work. I went through all the channels in the livetv app and around 1/3 of them are currently down. Also, for those channels that do work, when i was testing during evening timing, some of the HK and TW channels take much longer to load or they are constantly lagging and rebuffering. Pretty much the same issues plaguing UB box.
(Add: I tried some of these "down" channels in the dead of the night at 3am and surprise surprise, alot of them are actually working. Will need to do more testing and monitoring in the following days.)
-Not a good box for sports and EPL in particular. They dont have BT sports and Sky sports(british, not the south asian channel of same name). They do have astro channels but thats about it for EPL coverage in english.
For the good points(not alot i found so far)
-Most of the times, switching channels is blazing fast. Takes around 1 second for channel to load.
-Picture quality of channels is acceptable. Most channels are between 480p to 720p. Small amount of channels are lower than 480p but i think its mostly because those channels are not broadcasted in HD quality in their native source. More or less the same case with UB box.
-Vast amount of channels for those who like to channel surf. Have channels from india, thailand, vietnam, pinoy, indonesia and even cambodia.
-Unlike UB livetv app which has a category for adult channels, evpad has built a separate, password protected app for adult content. So no chance for kids to accidentally or intentionally access them. But note that evpad only has 3 live taiwanese adult channels. The rest of the channels are simply videos played on 24 hr loop.
So far, i would rate the box 4/10 and a disappointment. I used to own a UB gen 4 and while the evpad 3 is not worse, its also not much better. I have not played around much with the Mars vod and playback apps so far. I will be testing astro channels to watch epl matches during the coming wkend and maybe i will come back with more feedback after.
