Digital TV (DVB T2) Consolidated thread VI
kurau15s
Unless your wifi adapter uses the MT7601 chipset, it would not work. Refer to my thread over
am thinking of using ukobox with wifi usb to stream iptv in the car. anyone tried using this? read a few review in qoo10 that itv is pretty laggy. appreciate any feedback. thanks.
Durian Shell
i am using my monitor (see below) as a living room TV by connecting it to New Media Solutions tv box to watch mediacorp programmes using HDMI at resolution 1080i at 50Hz. The audio sound come out from the monitor itself
_________________________________________________________________
Processor
AMD Ryzen 1700X | EK-Supremacy EVO
Mainboard
MSI B350 Tomahawk Arctic
Graphics Card
MSI GTX1080 Gaming X | EK-FC1080 GTX TF6
Memory
Adata XPG Spectrix D40 2400mhz 2x8gb
Display
Acer XB271HU
Storage
WD Black NVMe 512Gb SSD
Casing
Be Quiet Dark Base Pro 900
PSU
Enermax Platimax DF Platinum 1200w
Audio
Edifier S1000db | Sound Blasterx AE-5 | Sennheiser HD600
OS
Windows 10​
Yes, you can do that......:)
https://www.youtube.com/watch?v=Isof8Qx9Ppk
Enjoy!!!!!!!
gregory_choo
it has more than 200 channels, some are very smooth, some are not.
try your luck, if the good channels are what you want, then it is a good match. by the way, the dongle costs only $5, low risk to take.
yes1705
If what you see is pixelated or frozen/still image, then the problem of your Draco is probably caused by below average signal intensity/signal quality for ch 31 (554 MHz) used for chan 8 and Vas, even if there is no problem for Vas.
What you can do it to do "Channel Scan" (pg. 7 of user manual) for this channel. While watching the indicators for the intensity and quality, adjust the antenna to achieve the best values (quality more important than intensity). After this has been done you have to verify the receptions for the other channels are not affected by the new antenna position.
If you don't have a copy of the user manual, you can download a soft copy using the link just before this post.
At my place, Channel 5 HD screen is constantly frozen. It is worse in the evenings / night. There goes my weekends trying to watch re-runs of blockbuster movies in full HD and OKTO programs (from 1 May 2019) showing on Channel 5 now.
Tried shifting the antenna but little room since I live on low storey with surrounding flats all around my block.
gregory_choo
Buy a RF extension cable for you antenna and place the antenna next to window.
MoxLotus
what are all the channels receivable from the DVB-T? excluding those FTA from mediacorp.
smart alex
what is the best digital antenna ?
I feel my digital TV channel is very jerky, will lag and suddenly stop every 2 second
I suspect it spoil liao
i_WaVe
Does anyone experience sharper image in digital setup box than using the tv antenna? I have a old non-digital tv that uses a digital setup box and is showing sharper image (wording as well) than my new led display (smooth/soft edges) which uses tv antenna. Any idea why is that so?
zenitro
Hi, I am currently facing a problem with me new media solutions box model number: STB2-T2D.
Been using it fine for around half a year and suddenly today it just keep showing the white colour startup page and restart after every 1 min or so just to come back to the same white background with newmedia sign. Anyone have any general idea what happen?
gregory_choo
up lorry.
typical nms.
dexter9898
call NMS for an exchange if still under warranty.
dexter9898
Due to different video processor and different LCD panels.
Cheap TV panels tend to display picture more softer.
GradeAbra
digital tv question
Hello, does anyone knows why recently when using digital tv to watch always autoscan oni its own? Isit normal last time not like that.
cybertech
CH U changes, has to retune my DVB program.
amazingone
So now the frequency 586Mhz is not used to broadcast CH U liao?
The Ch U on 586Mhz frequency now shows the image posted by cybertech, while the SD channel now shows HD instead.
Posted from PCWX using HUAWEI ALPS
Kiwi8
Deluxe Member
Yeah.
Now I gonna adjust my recording settings to use the channel at 570Mhz.
Kinda strange why they did that, instead of leaving the channel at 586Mhz and turning off the one at 570Mhz.
