Externally not possible unfortunately.
Guess no other super powered antenna can help.
I bought those cheap "200 miles" radius antenna that comes with a usb connector for power. Able to use until mid Sept/Oct 19 when I believe Indonesia start their DTV broadcast.
Used the dtv box usb port as antenna power source but after the mention period unable to receive all Malaysian channels. Tried placing antenna at different angles and place but only receive local FTA channels.
Suddenly thought about using a separate power source for the antenna at the original location and able to receive.
I measure the current draw from dtv box usb port using a dongle device and measure current draw of only less than 0.05A.
The separate usb charger max current only 0.15A but able to receive stable reception 90% of the time.
Now think of getting a higher current usb charger to try if reception can go 100% stable all the time.
So in short, use a separate usb adapter IF you cannot get reception if u power your antenna using the DTV box or DTV usb port. You can use your hp charger to try.
FYI my antenna facing south-southwest outside window along common corridor. Yes, not the ideal place but no choice.
Sorry for the long post.
