Oneplus 7!
KeYoKe
Not defensive lar.. I use many other os before so I know roughly their strong and weak points.. BTW can check can oxygen os moves batches of apps together?
Frankly speaking.. The best is still poco launcher.. Think I get use to it... Under mortification.. If I long press I can select to off the particular app nortification.. Super useful.. Think few done it.
no cannot move batches of apps together. OneUI can do it though :s13::s13:
Nakedtoes
OK thx.. So u see.. Most OS is there already.. I use colorOS and I find it very good too.. Many features that miui dun have.. Dun need to be a fan boy said other OS sucks own phone OS good..
As I said before if op7 pro is flat screen and at $200 more then I paid for k20pro I would wack it wo consideration and try oxygen OS.. But too bad..
afs_2921
Bro, did u try to adjust your keyboard setting? Took a look at mine and didn't see the issue.
Tried it with original keyboard and swift keys keyboards.
Thanks for checking bro. But seems like my issue still persists even with SwiftKey or reinstalling Gboard. I guess the only other way to trouble shoot is to factory reset my phone and see if the problem is still there :/.
Sent from OnePlus GM1910 using GAGT
DailyRoutine
I dont seem to have this problem on the stock keyboard. But if u need to move the cursor, u can actually just press and hold the spacebar and move left and right. That would move the cursor too
KeYoKe
:s13: u are right in a way la... my op7 pro i pass to my sis to use, she is liking it. thats why i got a op7 to use instead. so far so good, cheaper as i get it at 57x with amex
arfness
Just picked up 2nd hand OP7 for $550 (2 days old, incl receipt from newstar), so basically brand new! weee happy days back to OxygenOS, i've made peace that the camera will be super average, but i have the wifes Mate 20 Pro for photos :D everything else, theres 1+ :p
afs_2921
I see, thanks for that tip. Didn't realize there is this hidden feature on the stock keyboard, very helpful.
BTW I believe it's due to a 3rd party app that might be causing this behavior. Booted my phone into Safe Mode, and this occurrence does not happen.
Also noticed that this glitch does not surface until about 1 minute in after rebooting my phone. So probably when something starts running in the background, then this behavior starts. Will continue to monitor and try to identify which app it might be.
UPDATE: Found the 3rd Party App that causes this glitch : Meteor Swipe. Basically using it to simulate the Edge Panel that I use in my Samsung phones for app shortcuts.
Nakedtoes
SwiftKey u can adjust the height of the keyboard
crosswind
woh bro....thats a good deal...where did you pick up from?
WhiteAnt
Wanna check with all the bros out here if you guys face the same issue with your OP7 or OP7 Pro. The cursor seems to be overlapped by the keyboard, which makes it difficult to navigate along the bottom line of text. This happens to all my 3rd party messaging apps - WhatsApp & Telegram
Wondering if you guys experienced the same, or is mine just a standalone user issue.
don't have this issue but i have another issue which is hard to select the word i want. sometimes i tap on that word but it didn't highlight that but once in a while only. using swiftkey
seriously i think the moving of apps in batches or not isn't important at all. how often do people move their apps around the screen :s22: good to have but not a must
agree the long press notification to turn it off permanently you mentioned is v useful, hopefully more phones will have that feature.
i'm not sure if other phones have quick gestures like draw v, o, s etc to activate certain shortcuts? this is currently my top fav feature for op now. it may seem like nothing big to talk about but i'm actually pleasantly surprised how many times have i been using that in the past 1wk+. in addition, i have nova quick gesture too, so really created a super synergy when these 2 are combined
how you buy 2nd hand fr newstar? super good deal at 550 leh
edit: ooops i saw you got it fr carousell lol
Aicirt
Fluids NG , try this app...not bad wor
Mclairs83
who move the icons around all the time seriously?
my folder group or app has been pretty much stagnant all the time. till a point i don't even need to look at my screen and i can know where to launch my app.
The reason behind it's because MIUI launcher doesn't have an app drawer, similarly like iPhone.. that's why everytime when you install an app, it add its onto your home screen, making it extremely clutter and messy. imagine i have 100 over apps spread across my many pages.
The key main features that most people look at is performance, battery life, little to no bloatware, plus constant update. Look at iPhone as an example. Each an every major update, there are so many things they can offer.
hence OnePlus puts in UFS3.0, 90hz refresh rate, stereo speakers, promising at least 2mths update to their OOS. Just look around most of the android makers there.
1) HTC? Dead.
2) LG? Little to no update.
3) Samsung? Yes. but inconsistent. major android version like Pie to Q is still a question mark to most of the flagship model out there.
Just look their Xiaomi range of models. Maintaining MIUI on so many models. how long will it take them to fix bugs on each and every individual of the phone and how many models are guaranteed to have the next Android version?
Although there are so couple of shortcoming from Xiaomi, what they can offer where no competitors offer is.. PRICE. Trust me, there are small population that buy the highest end Xiaomi phone. Because the perception of Xiaomi in the market are CHEAP phones. That's why, their low and mid range always sell so well, whereas their high end which is the Mi series doesn't sell as good as the rest.
of course you can pick the competitor K20 Pro, if u feel that what OnePlus offers does not apply to daily use case or you are not attracted by it.. which is kind of weird.. who doesn't want performance? :s13:
leowweiqi
1) HTC? Dead.
What you said is quite true.
trento
If performance comes at a price, then not much advantage
1) HTC? Dead.
arfness
Mclairs83
I will say the 1+7 Camera is the most shocking thing i've seen at night jeez, it is horrific.
For anyone that's interested i used this, followed installation steps and it works 100% no errors nothing on 1+7 non pro:
MGC 6.2.21 APK Port with Marian’s config file for MGC 6.2.21.
https://www.theandroidsoul.com/how-to-download-oneplus-7-pro-gcam-apk-port-google-cam-camera/
1 photo both using nightscape mode: gcam vs stock
https://imgur.com/a/jtpQA0a
yes. OP cam is really . :s22:
