LiLAsN
- Dec 14, 2008
This thread is meant for all HDMI 2.1 & HDCP 2.3 related discussions.
Thanks for the detailed response. Just to inform you, your HDMI cable is not capable of a proper HDMI 2.0 bandwidth. Even if you got HDR, it is probably running at 4:2:0 chroma subsampling. And it is only capable of ARC. Even the stats on the page you gave me states it only runs at a maximum of 10.2Gbps. This is a HDMI 1.4 cable btw. Just that it's cable name is HDMI High Speed cable.
You will need a HDMI Premium Certified Cable with Ethernet. (Yes, this is the name for a HDMI 2.0b cable) It will have a 3D barcode and an orange border to show that it has been approved by the HDMI organisation to run at the maximum 18Gbps bandwidth. With the Ethernet part allowing some extra bandwidth to allow some HDMI 2.1 features like eARC, ALLM and so on on a HDMI 2.0b port. Only then, can you get true lossless audio that uses 37 Mbps thanks to the Ethernet feature in that Premium certified cable.
Only then, can you maximize your C9 and Soundbar via a HDMI 2.0 interface. If you want future proofing, there are HDMI 2.1 cables out on the market. But their length seems to be the limiting factor at the moment. But if you can afford it, then this will allow you to take full use of all HDMI features such as eARC even though you only have a HDMI 2.0b soundbar. Plus, you won't have to upgrade your HDMI cable down the line. But the price may be the reason why you would not opt for it. It is only limited to 2m too. If you want a longer cable, the price will jump exponentially to hundreds.
If you want, just stick to HDMI Premium Certified cable. Though it's best to at least have one HDMI Ultra High Speed cable (yes, this is the name for HDMI 2.1 cable capable of 48Gbps) so you can verify if its a cable problem when you have a new device plugged in through your HDMI 2.1 TV.
This is the HDMI Premium Certified cable's logo to certify it capable of running 18Gbps. But remember to get one with Ethernet for the eARC support.
Hi, thanks for the query. Right now I am using the
UGREEN 1m High Speed HDMI Cable with Ethernet Gold Plated Zinc Alloy Case Support 4K*2K and 3D
which I got from Lazada on both the TV -> soundbar -> media player. The media player I am currently using is the NVIDIA Shield TV and it's connected to the soundbar. The app in use is Kodi. Also, when I play any 4K movies using the app, the HDR logo will appear on the TV.
