Portrait shoot normally I don't put online forum. Maybe others can help on this matter.some portrait shots please..
normal reno is 600... where did you see it for 880?
ps see wrong, thought the screenshot in the post before mine was of normal reno, but is actually the 10x version
then again, $850 and $880 not much difference la.
normal reno sold at challenger for $850, really a lot for premium midrange. might as well get pixel 3a/xl.
I didn't attached actual size, not even half the original size, so if you zoom large to see then it will be pixelate.no worries...the photos that you uploaded seems pixelated , is it becos of the compression done by the hosting website ?
Yes for the 200plus price different. If u want get normal one I rather u buy mi9t.. The Sd730 is much better then SD710Worth to get 10x over normal reno for the price diff?
Just for the processor alone, yes. Not worth getting the normal Reno like what Nakedtoes said, you're better off with the mi9t or k20 pro with 855.Worth to get 10x over normal reno for the price diff?
Checked out some reddit users on Oppo, seems like they dont do much software updates?
XDA doesnt seem very active for Oppo either if I want to load a custom ROM with the latest android OS.
Any feedback? Pretty set on getting this phone already...
and the previous update also so long ago le, forget when come. I think their flagship should have better update frequency, but don't hold your breath.
Oppo has low custom support...Checked out some reddit users on Oppo, seems like they dont do much software updates?
no updates yet for sg set, yr set is from where ?Finally my simple case is arrived.
Beside this, new security patch July update also arrived today.
Mine is Malaysia set, actually I just get it 1/2 hour ago.no updates yet for sg set, yr set is from where ?
