which ryzen 3000 should i get?
Survivelater
budget with total 900$ - 1000$
I had a hyper 212x for the CPU cooler
will be reusing my case, HDD, SSD, PSU, and GPU.
what I need is
CPU + MB:
RAM:
and also if I would choose 3700x, will hyper 212x able to handle the cooling?
with GTX 1070 and my monitor can support up to 1440p and 144hz, games that I playing is
Tom Clancy's Ghost Recon® Wildlands
Apex legend
xonix
what I need is
CPU + MB:
RAM:
Apex legend
3700x stock tdp is 65w, hyper 212 x is rated for up to 150w
It should be okay unless you planning on doing aggressive overclocking.
ragnarok95
Senior Moderator
Senior Moderator
Your Budget is 1k. Buy whatever that fit your Budget.
Psycovirus
what I need is
CPU + MB:
RAM:
Apex legend
3700X included Wraith Spite probably cools as good as Hyper 212 and looks nicer to boot.
You can get the 3600 instead and it will be good enough to run most games without CPU bottleneck for years to come. It comes with Wraith Stealth cooler so Hyper 212 will cool better on 3600.
Also MSI B450 Tomahawk, one of the best B450 board.
For RAM, anything around 3200 to 3600 Mhz, 2*8GB for total of 16 GB.
tigerwoods
The stock amd cpu cooler is good but loud under load, 212 cooler is a better choice.
Posted from PCWX using Jedi mind trick.
grimfan
Just stick with included stock Prism or Wraith cooler that comes with the 3700/x and 3600/x respectively.
after seeing the price of 3700x might just settle for 3600 :(
Survivelater
any reason behind recommending b450 over the new x570?
i am quite interested in the argb and pcie 4.0 which i could somewhat futureproof the rig....
Shutterbox
what i can think of is:
1) higher official ram speed
2) more sata ports
3) more m.2 NVMe slots.
SkyShroud
Why not check the benchmark from youtube?
Like 3600x vs 3700x vs 3900x etc?
It will take a week before these benchmark become available I believe.
Phen8210
what I need is
CPU + MB:
RAM:
Apex legend
Hyper 212 is a mediocre cooler.
In 2019, its size (160mm) to performance (temps/noise) ratio is garbage, the only good thing is that it's cheap. But it's not going to give you any decent OC, so no point getting it IMO..
The 212 mounting mechanism and build quality is also not good, i realized it after using a lot of other HSF. It's not the worst though.. in the end it's just a ~$30 HSF.
Also, the 212 has 2 mounting brackets for AM4, one will make the heatsink horizontal and the other vertical. The horizontal one is going to screw your PC airflow up and the temps are going to be terrible.. trust me I've used it. If you ever get one, make sure it's the standard (vertical) one.
You could do a mild overclock with the 212, really MILD. But it's no point since stock speeds with boosts going to give you better results.
On the other hand, the free Wraith Prism that comes with the 3700x processor can match the 212 performance. You are better off saving the money for a cooler that can make a difference.
SkyShroud
Actually hor, I can't find much comparison between wraith prism and hyper 212x or 212 evo even.
Where you all see such comparison sia?
Survivelater
bought Kingston HyperX Predator RGB 16GB (2x8GB) DDR4 3200MHz for $133
to pair with ryzen 5 3600x and x570 board
is it a good price? is it a good product?
SkyShroud
According to much reviews so far.
3600x and 3700x and up all provide comparable performance when paired with 2080ti
will have to wait for review that pair it with titan to see if there will be any difference
if there is still no difference....
3600x would be good enough for gaming for now
to those who seeking to oc
the lower tpd of 3700x will sound great
ragnarok95
Senior Moderator
Senior Moderator
Technically, anything below 3700X are good. The 3600X will serve you well.
hg2
Price : There will always people tell you got "carroted", on the other hand, there always some reasons/values in getting from local store and paying that premium. Unless you really a fulltime pro, who can spot a good deals online, dont be a penny wise dollar foolish...
Product Brands : Used to pair well with MSI boards on intel. Kingston, Corsair, GSkill are openly promoted by Toppc youtuber/MSI staff. Subscribed to his insider videos but all in chinese and naggy, disorganised and painful to watch. After all he one of the world recorder holder for DDR4 OC, so they are still some eastern eggs to find in his rantings.
Most recent video talk about memory oc to 4000 on Godlike, and why u shld use reputable brands... after all he eat&sleep with ryzen 3000, at least 9mnths ahead of all of us....all the youtuber including LTT, Nexus yearly pilgrimage to Computex just to learn all frm e gurus' guru
I think someone also asked why X570... these new boards are purpose build for Ryzen 3000, tightly integrated with the CPU's features (e.g, PBO, infinity fabric) and extra heatsinks and additional layers to preserve the signaling integrity. For "priority" bios updates, extra stability, less BSOD...i think it's already worth the extra bucks...
I'm not representing the vendors, just an user on the street who got "carroted" since AppleI...
