ahbuiszxc
- Jan 18, 2015
Which broker are you using?
Based on the book, with my investment amount, it should be POSB for local and standard chartered for global.
Posb? You mean the dbs vickers account?
The POSB invest saver
Hello. I need some help here. After reading rich by retirement, for my age, I would need to allocate 80% in stocks and 20% in bonds.
For the 80% in stock, 40-40 local and global. I have approx $10k currently to invest, should I make a lump sum 40-40 split between local and global? Subsequently, I'm able to invest 500$ per month. How should I allocate the fund for the 40-40 local and global stocks.
First month local and the next month global and repeat?
Anyone can advise me?
So.. are u going to purchase vwra? Or have u purchased itAssuming that you are in for the long haul; an investment decision based off a 2 year time frame is myopic.
With that being said, the only correct answer to your question is: nobody knows for sure. (which is not a bad answer)
Your question then brings us to an important assumption of the broad based index investment strategy. While we do not know which country/sector/counter will perform; we can expect the economy as a whole to grow. Thus, the foolproof move is to buy everything (or almost everything) to ride this growth. So yes, I will think that you should continue to stay invested in EM.
On the other hand, most people choose to ignore EM since it accounts only for ~10% of the market. How significant this 10% is will be for yourself to decide.
Sent from Ilovennp using GAGT
I've always been on 100% vwrd; which isn't much different from vwra. I forsee myself still dca-ing into vwrd.So.. are u going to purchase vwra? Or have u purchased it
Why dw nikkoHi
I read the book, may I know which platform offers the lowest fee to buy SPDR ETF?
I checked posb invest saver, it only covers Nikko ETF.
So am wondering, sorry very noob. Thanks.
Why dw nikko
Just wanted to check if anyone has recently became eligible for SCB priority? If so, can the AUM requirement of 200K done purely through the market value of the ETFs held with SCB?
I understand one should consider transitioning to IBKR upon hitting a higher invested amount but asking for those who wish to stick with SCB all the way![]()
Hi Shiny Things,
I have jus read ur book on retirement investment. Really thank u for giving useful insights on investing basics. Definitely help a investing noob like me.
I have a question on for the overseas ETF investing, u suggested scb trading. In that case, it is subjected to at least 10 dollars transaction fee. Would it be correct to say it is better to accumulate money before investing i.e if u decided to invest 400bucks each month into overseas ETF, u accumulate say until 2k then buy using lump sum. Or would u recommend still monthly buying of 400 bucks worth of overseas ETF.
Also if I am not wrong the Maybank RSP is discontinued. What would be the next best option for local investment of 400 sgd
Is it the latest edition the black or green colour paperback?
i rather stay on iwda + eimi because if EM not doing well i can sell it off.
VWRA you are stuck with it
yeah i understand but EIMI has been trending sideways since 2017
is it advisable to stay invested in EM?
Hi
...Mate, if you want a 24-hour response time I charge for that.
Anyway, yes, you've got the right idea.
Nothing wrong with that, though I reckon you'll find IBKR works out a shade cheaper in the long run. Anyway, yes, you absolutely can hit the AUM minimum based on equities.
1) Sort of. Remember, you only really need to buy one counter each month - you don't need to split it and buy three counters each month. So if you're buying IWDA once every two months or so, that's fine.
2) Yeah, sadly MBKE discontinued their monthly investment plan. POSB IS is the next-best choice, and it's perfectly good.
It's only ever been green...?
You're kind of missing the point! The point of having a diversified portfolio is that you keep buying things when they're not doing well, so that when they do start doing well you've already bought some. That matters whether it's stocks or bonds or whatever.
Use POSB IS and buy the Nikko ETF. The Nikko STI ETF and the SPDR STI ETF are basically the same.
It's perfectly OK to start buying VWRA instead.I've always been on 100% vwrd; which isn't much different from vwra. I forsee myself still dca-ing into vwrd.
