Hi Joseph99,
Customers may invest in BCIP using cash or SRS.
Hey OCBC! Any chance you'd consider cutting the minimum transaction fee on BCIP? $5 per clip is a lot for your smaller customers who might only be investing a couple hundred dollars a month; POSB IS is a lot more competitive than you are.
(Oh, and if you added an international-equity ETF option you'd win a whole lot of brownie points from the crew on this thread.)
Most people here must be investing at least 1k per month. All using IB....not MBKE
On the contrary. I'd say most of the people on here are investing less than $1k a month.
Ultimate question: in posb IS, can you rotate your monthly investments and rebalance by entering the amount manually and not auto recurring???
Unfortunately no, you can’t do this - POSB IS isn’t perfect but it’s the best we’ve got for small investors.
When i have reach my target allocation 40 40 20 in the 5th month, my next investment will still be rotation among the 3 assets to be back to 33 33 33 then 40 40 20 and the cycle repeats
After 40 40 20, the monthly investment amount will not be fixed and will depend on which asset does not meet the target % and top up from there??
I’ll be honest, I thought it was pretty self-explanatory? You’re investing x dollars per month; each month, you spend that x dollars on whichever one of your three funds is furthest below your target percentage. Eventually, that’ll make you converge to your target percentage.
Shiny's book is like my martial arts manual now, am literally hugging it to sleep.
…doesn’t that get uncomfortable?
If not going for bond, reits can be a good consideration where es3 + clr + iwda
No, in fact I don’t think this is a great idea. Couple of things here!
Firstly, saying “if you’re not going for bonds”… there’s no reason for people to “not go for bonds” in the first place, and it might confuse people when you say that.
Secondly, REITs aren’t a substitute for bonds. REITs are a lot riskier than bonds, and a lot more volatile, and they do a lot worse in market downturns.
Hey ST and senior forumers here,
Was scrolling through over 400 pages & got the ebook (good read btw).
1. S$1k into IWDA via IB every month
2. S$500 into G3B via POSB IS every month
3. ~S$900 savings into high interest rate savings account (~2% p.a) for the bond component. I am looking to get a house within the next 2 years and would prefer to have the added liquidity.
Hmm. If you're saving for a house in a couple of years, I'd keep that lump of cash completely separate from your retirement portfolio, and just put it straight into a high-interest savings account.
Other than that, this looks fine, though I'd suggest a couple of things:
1) You don't need to buy IWDA and G3B every month. You can get away with buying IWDA one month, G3B the next month, etc etc etc... it'll save you a few bucks on transaction fees.
2) Is there a reason you're not going for a 50/50 local/global split on your equities? Don't tell me you're buying more international equities because they did better in the past.
Yes there is below but in the form there is no tick for lse
You seem to have confused currencies with exchanges. The list in your screenshot is a list of currencies; the London Stock Exchange is an exchange.
is it still recommended to invest in mbh with the interest rate cuts?
Yes. MBH is perfectly good, and you’ll find it yields more than A35… see below.
how abt ocbc g3b? any diff from posb Es3?
No, they’re basically the same thing.
Now some bond questions:
ST can u kindly explain why MBH became a better alternative than A35? It was stated in the book that it is higher risk and higher yield than A35. I can understand the higher risk due to corporate bonds as underlying assets than govt bonds. And with higher risk the coupons of the underlying bonds also have higher rates.
However, when I checked the dividends given by MBH vs A35, it is actually alot less? Seems the higher risk and higher coupons is not translated to higher dividends for the ETF..
Don't get how is it higher yield... And how is the higher yield translated to holders of MBH?
What are the pros and cons between buying ssb and mbh?
Den why is mbh recommended?
I prefer MBH over A35 because it has a higher yield - and it’s a more than fair tradeoff between the higher yield and the slightly higher default risk.
I prefer MBH over SSBs because MBH is easier to get in and out of (you don’t have to wait for the monthly issuance) and there’s no cap on how much you can invest.
Kenneth - I think the reason you’re seeing a low dividend yield for MBH is because the end-of-2018 dividend was only for about half a year, because the fund only launched in September 2018. So if you look at the actual dividends that MBH paid out last year, you’ll be understating the div yield.
At what exact amount should I choose fixed over tiered commission?
I have received dividends from ES3 and my salary bonus this month. I wish to use them to purchase IWDA in a lump sum. Thank you.
You’re thinking a bit too hard about this? Just leave it on tiered.
Can you point the link that where you read that trading in London Stock exchange got 'penalty' for removing liquidity?
And there is the issue with adding and removing liquidity when u trade in tiered.
Anyone knows how much r u penalised or rewarded and by how much when u add or remove liquidity ?
Hey Swan, this is incorrect and Limster is correct. IBKR’s tiered pricing charges the same price for LSE trades, whether you’re adding or removing liquidity. You can check it right here:
https://www.interactivebrokers.co.uk/en/index.php?f=1590&p=stocks2
I see where this might have come from, because when you trade US equities with IBKR, the tiered pricing does give you access to maker/taker (or taker/maker!) rebates (and I’ll grant you, BATS UK offers lower prices for makers, but you’re not manually routing to BATS, are you?!). But that doesn’t happen on the LSE, it's the same price whether you add or remove liquidity… can you do me a favor in future and check before you post, just so people don’t get confused?
So he is not the god in Money Mind anymore? Hahaa
Ignore Purplestars, he’s been raging out in this thread for close on a year now.
He came in arguing that high-interest savings accounts were somehow better than A35 or MBH. I listened to him, agreed that high-interest savings accounts were a good idea for emergency funds but not for your regular retirement savings, and then he chucked a gigantic tantrum because I didn’t agree with
everything he said.
I think he was also the guy who was chucking a tantrum because he bought A35 and then it went down (because interest rates went up toward the end of 2018). Last I checked he’d spewed it all out at the lows, and since then A35 has gone up about 5% in six months. Moral of the story: patience is a virtue.
