Xiaomi vacuum robot users lip lai please
athenodorus
Yes Google and Alexa.
Have not tested it yet..
To use google Home:
Download and install google assistant APP.
Ensure your google assistant account is same email address as google home APP account.
On the bottom left, click into the explore icon in google assistant APP
Search “clean robot” click on it and click link button.
Login with same account as the Minihelpers app user and login.
It is linked!!
User Say to google home device :
“OK google, let me talk to clean robot”
Google home a ays:
Greetings!! How can I assist? You can say ask clean robot to start cleaning. What would you like to do?
User says:
“Ask clean robot to start cleaning.”
Google home says:
Cleaning will now start.
Robot starts cleaning!!
So troublesome? I just say hey google, start cleaning and it will know I'm referring to my s5 robot and initiate it.
Vulpix
Moderator
Moderator
Well, it takes a fairly long time to get Google approval for full integration. For products that have partial support, you need to "talk" to the device. The Homey hub took 1.5 years to get approval for full integration, not sure how long this will take.
phiber
For Hydra S7 user, anyone has encountered issues when setting up a schedule or no go zone? It does not seems to work for my case. I am using the minihelper sg apps.
Check that your quiet time is not enabled.
When quiet time is enabled, the schedules will not run at all during quiet time even if it is set.
apple555
It is working ok now. Thanks! Think some software glitches. The schedule does not appear immediately once I have created them. It somehow only appear on the next day.
While for no go zone / virtual wall, I found that it can only be set once i have pressed start cleaning. No issue now. One thing I hope it can better is NOT to restrict 10 virtual wall :)
phiber
Good to know! I actually forgot to manual vac last 2 nights but have the vac scheduled for room cleaning and edge cleaning, woke up and saw the records that the S7 did cleaning! Very nice!
I I have feedback to minihelpers and they are increasing the virtual wall limit.
But suggest using the virtual wall as blocks instead of lines.
Remember u can select different maps for different schedules too!
Synchron
Gotten the Hydra S7 during 1111 and gotten free xiaomi fan and only realised the fan isn't portable ones..
vkvkvvk
Anyone can advise these vacuums with the mopping feature can add those biodegradable detergent ? Add like 1-2 drops etc
Headshotzx
To use google Home:
It is linked!!
Google home a ays:
User says:
Google home says:
Hey mate - you got it to work? For some reason I'm stuck at the link accreditation page. My minihelpers details don't work on the prompt page after clicking link.
cydutzyahoo
should I try to buy s7?
I don't want shitty experience like viomi
I currently own S6 but thinking of changing
Spheredome
Not all vacuum robot water tank works the same. Models like Viomi v2 and S7 family uses where there is no water pump, you can use very diluted form of clear floor liquid.
Those that have water pump type then have to selective with cleaning floor liquid that has no bubble and wax. One such suitable type is hizero liquid.
wongminmin
wait for more users, no rush in buying unless it is super worth it.
viomi s7 come from the same manufacturer, so meaning their hardware is more or less the same, just the software is cater to their respective seller requests. my guess is users been complaining about viomi, so they just abandon the brand...and replace with own branding....
To me, i will still remain neutral view for s7 but my thinking is 换汤不换药 :(
u can buy according to this timeline.
Spheredome
When xiaomi robot meets Ecovac robot. Xiaomi is tiny but has the agility and speed. Ecovac has the size, sees much farther, works stealthy but slow.
sellun
I'm using hydra s7. Planning to use it for pure mopping. Anyone can advise if the scrubbing mode is for mopping? The manual is very badly done. Only basic information..
Sent from HUAWEI BLA-L29 using GAGT
shawniiex
LOL wtf the size of that ecovac is just ridiculous.
Whats the point when can't go under most furniture?
Aresden
lol y the ecovacs so big wan? does it do air purifying as well? Or it just has a bigger dustbin and requires less maintenance?
Spheredome
This is the Ecovac robot air cleaner. Equipped with the same Lidar as robot vacuum. :)
sinori
Does the app from mini helper have any notification? I schedule the cleaning but there is no notification about it.
kelvinang
Roborock S5 user here.
Notification that says "Fan malfunctioned. Reboot system" - anyone faced this before?
It's only been 2 months on MAX, everyday schedule.
I tried rebooting the system and cleaning out everything but the fan is still having the jerking motion (like car engine stalling, start and stop)
