2018 Google Pixel 3 and 3XL...πŸ˜—πŸŽ‰πŸ˜΅
Those online e-commerce or Facebook
Are these drainers?
Been using aod since day 1 on my p2xl and p4xl. Dont think the battery drain comes from this.
On my p2xl which is pretty optimized already is about 1%/hr consumption on idle.
Wifi on
Mobile data on
Aod on
Location on
Sync on
Volume on
Vibration off
Adaptive brightness on
Adaptive battery off
limmk
https://9to5google.com/2019/11/13/pixel-3-early-shutdown-battery-issue/amp/
Anyone having this issue? I'm finding my p3 draining faster. No shutdown issue yet. Hopefully local sets are not affected.
Ordered day 1 so it's probably early stock too.
One of my p3xl had this issue. I factory reset both (same apps, same settings) and you see below that one unit clearly discharge/drains faster than the other (without doing anything, just idle). Seems like the phone did not doze properly.
jaspreettttt
Whoa could be bad optimization. Will try that and see. Thanks πŸ‘πŸ»πŸ‘πŸ»πŸ‘πŸ»
Hmm don’t have shutdown issue
But it seems like it’s draining faster.
But it can last me a day inclusive of playing earpiece bt for like an hour balance less than 20%.
2 hours ish ost.
What should I do
limmk
2 hours ish ost.
What should I do
So far no solutions. Even google have no answers. Keeps directing to their template answers. Reboot, safe mode, uninstall apps etc
