How do you even run the LAN cable? Use double sided tape then. I am using double sided tape. Make sure it's thick and strong enough.
I waiting for UDM but hear it won't be in SG till March...Looking to replace my ea8100 to udm!
The next closest thing would be the UDM Pro liao which will be super duper expensive...The best product would be UDM without the wifi. That would also bring down the cost a lot.
The next closest thing would be the UDM Pro liao which will be super duper expensive...![]()
How did you get it? You use forwarder?Just got the UDM. Hope it will reach the shore soon![]()
Which forwarder? Can you recommend which one you used?Yes forwarder![]()
Excitef. Although no ax
Nice thanks. A few years back I tried to ship to Comgateway old address via Ubiquiti site but was rejected. Good to hear now can.Comgateway for me
Most reliable and fast. Although bit more expensive. Vpost is another alternative and usually new account should have coupon but the only downside is they r very restrictive to what items u can ship.
Surprising meh. UDM literally only released last week leh, of course more people on USG.what is this UDM ? looks like smart speaker .
mostly here all using USG ??
am i the only one using erpoe and unifi AP only ?
Yes forwarder![]()
Waiting for review. Finally they released for mass public. Not sure worth getting it at this point since alot of wifi 6 routers are coming out real soon. Eyeing on velop wifi 6 at the moment.
I don't think a single udm can cover 2 storeys. Wonder if udm + their beaconHD would work.
Ya previously my setup is 2 x nanohd but sold them all cause very messy with multiple equipmentss and cables.UDM + flexHD? Or mount a nanoHD at 2nd floor? UDM is like a nanoHD, very strong.
