Cyberboy128
- Aug 20, 2000
Thread created for users to share experiences.
Supposed to have faster & more stable wifi since there is a separate 1 gbps allocated for that.
Makes more sense IMO. What's the use of combining into one pipe of 2 Gbps unless one downloads tons of porn daily?More bandwidth for big family.
Two pipelines of 1 Gbps each FTW.Supposed to have faster & more stable wifi since there is a separate 1 gbps allocated for that.
Makes more sense IMO. What's the use of combining into one pipe of 2 Gbps unless one downloads tons of porn daily?Two pipelines of 1 Gbps each FTW.
Noob question. Will there be online 1 WIFI connection or 2?
heng ar
i asked for 5gbps multi-giga ONT network
now using full 2gbps on one pc
heng ar
http://www.starhub.com/2gbps
This one seems to be better than SingTel 2Gbps plan — two separate 1Gbps ONT ports and one ONT port dedicated to StarHub Fibre TV.
SingTel 2Gbps plan is also bundled with WiFi Mesh but it comes with ONR which prevents you from using your own router.
https://www.singtel.com/personal/products-services/broadband/2gbps
SingTel 1Gbps+1Gbps plan allow you to connect your own router but it is more towards gaming.
https://www.singtel.com/personal/pr...and/fibre-broadband-plans/fibre-gaming-bundle
Still most users will not need 2Gbps plan, in fact 500Mbps is enough for most users. Then buy your own Mesh solution if you need that (eg, not able to lay Ethernet cable around the house).
Can I know how you setup for your pc to get 2gbps? Thanks.
Set up is no problem.Not that hard actually. You just need a capable router/switch that can bond two lan together, and your computer need to have two lan port. You can get an external one, combine with your onboard lan. You can get both links bonded.
My NAS is bonded at 4gbps, and my desktop is bonded at 2gbps. I'm using a cisco rv345 as my router, load balance my wan ports between SH and MR. Also using cisco SG250 as my POE switch, for my WiFi APs.
Look up on LAG (link aggregation group). You will get how it works.
Another way is to use multi gigabit capable switches
The question is do you really benefit from using 2Gbps plan? Most consumer need 2Gbps plan?
I read that Sg is second fastest internet speed in 2019 and our average speed is still below 1Gbps.
Can you really get 2Gbps download speed in the real world?
If no real benefit then why use 2Gbps plan?
