2018 iPad Pro
with the new ipadOS, the mini keyboard is quite useful.. but it will be better if the size can be customized by user... now seems to be only one fixed size of the mini.. right?
SpeedWeed
where to buy 12.9inch ipad pro casing with slot for pen?
challenger best denki harvey at my area doesn’t have them
SyraLeo
anyone experiencing rapid battery drain on 13.2.2 ?
as i draw stuff in concepts or morpholio trace, i can literally see my battery percentage falling in real time... wtf?
szeli
what do e batt stats page say?
SyraLeo
nothing, it's been a while since i used an Apple device, I downgraded to 13.2 and found all my data gone.
tried to restore with yesterday's backup but kept getting an error, no code or anything, just error, how wonderful of Apple. "Error, good luck figuring that out".
for some reason after i logged in to iCloud, i got my GoodNotes data back but my Morpholio and Concepts data are still gone.
dont know how to get my data back... its not super important but i would still prefer to have it back. so irritating...
szeli
u too impatient liao, should have let a batt stats gather e data then see which app is causing e drain.
SyraLeo
im not the only one who has this issue.
I managed to recover my data, updated to 13.3 beta, battery seems the same. right now it seems morpholio trace is sucking it dry, as does firefox and concepts.
but 13.2 has no such issue, i can draw all day and the battery remains strong.
szeli
immediately after updating OS it will do some background tasks that will drain batt I think that’s established knowledge.
SyraLeo
you mean to say it does background tasks for 2-3 days non stop?
anyway, i restored and backed up multiple times until my CC got blocked because amex thought i was hacked.
i dont know what I did, but it is now discharging normally again, been using Firefox for the past 40mins, a little morpholio trace and goodnotes 5, still at 100%.
using 13.3 beta 2.
foxriver
Usually pencil usage will drain quite a bit?
I use GoodNotes daily with pencil for note taking, average every 3 hours (constant on screen / note taking) drain about 20% +-
SyraLeo
mine was draining 10% in 30mins so... yeah. anyway its "fixed". no idea what i did but dont really care anymore as long as the battery lasts.
asianfish
Anyone knows how do I make Google Calendar appear as Today View on Home Screen instead of apple's default calendar?
luvwings
i think u can add the email first, then edit the today view to include google calendar and shift it to the top of the list. thats what i just did yesterday.
