On the mi tv remote.
Sent from Razer PHONE 2 using GAGT
Hi bro,
Unfortunately both my Mi TV and Mi Box S remote are a bit different from that. Instead of 3 dots, it's 1 big circle. Pressing that button brings me back to the Home screen.
Like this:
Hi bro,
Like this:
The top one is the remote controller of the old type of TV4 and the bottom one must the Mi Box controller. The Global MiTV4's HDMI 2.0 cannot be set by the "Home" and "Menu" (3 horizontal bar) buttons. Think they can only be set through the "setting" controls of the Android TV OS. correct me if I am wrong.
Hi bro, as i have checked, there is no setting for HDMI 2.0 in the Mi TV and Mi Box S, unfortunately.
Btw, anyone knows how to install Netflix APK onto the Mi TV Global set? If can do this, i will have no further need for the Mi Box S. I tried downloading the APK and install on the TV, all went well, until i open the app it said something like "This app is not compatible with your TV, etc".
Thanks!
One should be able to install the Netflix apps in MiTV but it will only have 850x 480p picture quality which is acceptable for normal viewing.
I have posted this link before, some said it is working; other said it is not.. please let us know if it works in Global TV model. These are modded versions, do not attempt to update them.
https://skyjuiceiswater.blogspot.com/2019/04/playing-netflix-movies-in-xiaomi-tv4.html#jumpspot3
I have also Mibox S but I never use it.
Having some issues with my Mi Box S hope the bros here can help me out.
I have it paired with a Mi TV 4S Global version, and notice that when i scroll through the apps, or within the Netflix app, scroll from show to show, the screen will flicker once before the preview/auto-play starts playing. When playing YouTube or Netflix videos however, buttery smooth with no flickering. It only happens when scrolling through apps/videos.
I have tried different HDMI cable, different HDMI port, and even put the Mi Box S on another TV, not able to replicate the problem. I don't think it's the TV issue as my Mi TV 4S is global version so comes with Playstore (only no Netflix) and it doesn't flicker as i scroll through the apps or in YouTube.
Might be an issue with the resolution in Mi Box S but i've tried 4k/1080p/etc still flickers.
Have searched Google but doesn't seem to have anyone else facing the same issue.
Thanks in advance!
P.S. Will try to take a video and post here soon.
Nope, doesn't work unfortunately. I'm fine with viewing Netflix in HDR only but have some issues with flickering when using Mi Box S. Quite a weird problem.
Posted in another thread here for those who are interested:
Nope, doesn't work unfortunately........
Shipping on delivery since 5am this morning. Let’s hope it’s today...
@Rapture Try this netflix file for 4S
https://drive.google.com/file/d/1Ydnba-mVraw2WmuOaBoYH9aWcL0NsNHb/view
Thanks for the file bro. Just tried, similar to the one on Aptoide TV, causes the Mi TV to hang and reboot. Appreciate it though!
What if you try the earliest version in Apitoide TV? go to other version and select one of the very old ones..try other version also.. Are u not able to install the Netflix from the playstore?
Just got my set. It’s the Russia model.
I can’t seems to go to patchwall to see the tv specs, any idea how to go about doing so?
Uhh I can’t find CPUz in the Google play store. Means what ah?
Also, I can’t set the contrast and brightness all since the patchwall os is not working.... any advice?
