Xiaomi TV Discussion Thread IV [consolidated]
richneo
I have some issue connecting the soundbar to my mi tv. Mi tv behind got optical out and the red white ( I think it’s called rca?)
My sound bar have coaxial, optical that’s all. The optical port is connected by my pc.
So I’m left with rca on mi tv and coaxial on sound bar. Any idea how to link rca and coaxial together?
The coaxial on your sound bar is spdif digital input. You need to convert the red white rca from your tv to spdif digital before connecting to your sound bar
1a2a3a
So I would need a red white cable on one end to mi tv and the other end is a single coaxial to soundbar? Is there such a cable in the market?
pcuser123
Your model is a Russian set. It has a headphone jack and a optical SPDIF. The 3 RCA is for AV input to set top box. Since you already used the optical for PC, only option is to use Headphone (3.5mm jack). The other way is to buy optical splitter or HDMI ARC to SPDIF adaptor. Suggest to use splitter because HDMI ARC is hard to get them to work (I tried one and failed; just ordered another one).
cscs3
Was told that all xiaomi tv has DTMB feature after 2014, meaning it is digital ready in Singapore. Anyone using China set can share if can watch sg channels with just a digital antenna?
Think cannot as DTMB is china system.
sumantochong
HDMI Arc I used Ugreen one ok leh. It got stated for HDMI Ar TV. I hooked up to my Yamaha Yas soundbar with HDMI Arc ...
pcuser123
Some will work but some will not for some reasons.. Troubleshooted together with the seller's Technical guy online. He could not solved the problem and finally, refunded part of the money.
1a2a3a
Anyone notice that when you set screen mode to vivid, the tv will auto brightness according to the scene? Like certain scene will be brighter and etc? I often notice that the scene will be bright first then it will reduce down to not so bright. It felt like from hdr to sdr... Is this normal?
pcuser123
Which model of the UGreen are you getting to work with MiTV ARC port.. according to this seller, the model of his UGreen HDMI Audio Extractor does not support MiTV
https://www.lazada.sg/products/ugre...o42.searchlist.list.4.73fd231dHN0IPd&search=1
sumantochong
Sorry & my apology to you bro for my ignorance to read previous post. The one I hook up for HDMI Arc is for my Sony 43” to my Yamaha soundbar HDMI Arc, not XiaoMi Arc as my TV 55” yet to arrive ... Paiseh Paiseh
