[IP Cam] Xiaomi IP Camera Xiaoyi
purpleberry
Is there a way to set record to SD card and overwrite the older files automatically if we dont clear it?
eyz
am using xiaoyi ip camera with 1.8.6.1C firmware and the latest mi home.
I'm not able to view the camera using data connection. but I'm able to view using WiFi, the same 1 that my up camera is using.
anyone know how to solve the issue?
Palmster
Can I confirm xiaomi web cams don't support IP port forwarding ? And I need to use their mi home app (only)?
eyz
Finally found out the reason why I can't view the Xiaoyi IP camera when I am outside. This issue doesn't happen when I am at home, using the same network at the camera.
I am now able to view the cameras off-site by using Yi Home China apps. Yi Home International is not able to pair the camera.
However, I am unable to add Mijia 360 camera using the Yi Home China apps. I am guessing that Xiaomi and Xiaoyi had separated their products/apps management.
j4nfz1981
Those having offline issue, hv u resolved it? Mine using like weeks. Getting offline occasionally. At the same time, other brand camera connected to same network still working fine. And is actually futher away from the router.
singha39
Suddenly the rewind and view playback function is not there in my apps,anyone know what happened? TIA
deodorant
Well for me changing from China to Singapore solved my lag and stuck at initializing and offline issues.
duabuiji
looking to replace all my three yihome cameras due to the app took up a large space at the main page with their stupid cloud service advertisements.
wrote to them couple of times even though confirm plus chop will get ignored.
can recommend any brand camera powered by micro usb and having clean adfree app?
j4nfz1981
Yihome is using mihome app?
thumbtacked
If I buy the xiaobai 360 cam from xiaomi China means I can only use China server?
What's the difference between this and the chuangmi or imilabs 360 cam? They look like the same thing but the chuangmi connects to SG server.
Want to replace the yi home cams that I bought in 2016... Recently lots of problems like outside cannot load at all (stuck at 5%). Even at home the feed doesn't load too.. keep having to relogin to camera then can view, or clear app data and reinitialize the cams. Weird thing is this happens on my S9 and iPhone. On my spare Huawei it works very well!
thumbtacked
Saw your post and tried yi home China app, now both cameras can load just need to wait a bit haha, thanks!
Btw how to get the app for iOS? Edit: nvm found out need to change to China app store
thumbtacked
Can I use the in app update to update to 1.8.7 firmware? I remember last time is cannot do that otherwise camera will not be able to connect
edmund_goh
Hi gurus.
I intend to buy the Xiaomi 360.
However, I realise that there are 2 versions.
The China version and the global version.
The china version have Motion Tracking (not detection) meaning the camera will pan and track the movement of individual.
Not availablen on the Global version.
Can anyone confirm this?
And how many days ofnfootage can the camera save?
[Mubiq]
Hi peeps, I have setup my xiaomi mijia 360, 1080 camera. I can view the camera while using my home WiFi on the Xiaomi home app. However when I tried to access the Xiaomi home app on my 4G mobile network I could not access it. It's always stuck at the 20% mark.
Anyone can help
9N1Y9N1Y
Anyone got problem with xiaofang? I got a few camera at home but the xiaofang keep stuck at connecting 1/3 after pairing. The rest of the xiaobai got no problem.
