Xiaomi TV Discussion Thread V [consolidated]
woocheekiat
Ya, I inserted batteries. In fact I switched batteries after the 1st pair don't work. Unfortunately, the second pair didn't work as well. :(
I PM Mu TV Store. Hope they can help me....
You need to place the remote about 20cm from the tv sensor.
sumantochong
Anyone can recommend wireless keyboard that comes with touch pad for my XiaoMi TV 4s? Like this one ...
i buy the tv thought can play netflix so no need to buy other things. =(
Try this. 480p only but should be okay for 32inch TV.
https://m.gearbest.com/blog/how-to/how-to-install-and-play-netflix-on-xiaomi-mi-tv-44a4c4xpro-9335
Or try this to see if you can get 480p or 720p for your Mi TV 4A.
https://skyjuiceiswater.blogspot.com/2019/04/playing-netflix-movies-in-xiaomi-tv4.html?m=1
BTW, for those who have Mi TV running official Android TV OS but not Netflix certified (eg Russian version Mi TV 4S), you can try the following, 480p only.
https://youtu.be/myiH7q7wtvY
For me, the Mi TV 4X Pro 55-inch is a great package if user experience and picture quality are your primary preferences. You will not get better 4K HDR performance on any other TV at this price in India. Apart from the unavailability of Netflix and Amazon Prime, there is no major flaw in the TV.
pcuser123
Oh alr did that..still.showing HDR on Netflix but still dark..thanks tho
Sent from OnePlus HD1900 using GAGT
Try to turn on the HDMI 2.0 setting from off to on on MiTV as well as in MiBox S
"select the correct HDMI input on the TV. After that, press the Center Button of the TV's remote to turn on the HDMI 2.0. This will allow users to turn on the Mibox's "Enhanced HDMI setting""
kitz79
Dragon TV
Anyone installed Dragon TV on MiTV 4S? I installed mine but can only watch live streaming. The movie / drama section only audio but no picture.
Appreciate advice if there is a solution. Thanks!
RaptureM3
Small hassle with Mi TV.
Mi TV 4S -> YouTube / Aptoide / Amazon Prime - OK (but no Netflix)
Mi Box S -> YouTube / Netflix - OK (but no Amazon Prime)
Lol. So if you use YT/Netflix/Amazon Prime as i do, you will need 2 devices. Thinking of the Amazon Firestick 4K so that 1 device can run all 3 programs that i watch.
gregory_choo
you can watch prime video on mibox s.
after the upgrade to pie, you will find it in the playstore.
at the moment, you can watch via chromecast - run prime on the handphone, select the video, press chromecast button, then turn off the phone if you wish.
