The AMD Zen2 Ryzen 3000 Discussion Thread
platee
What cooler and case config? On a 3600 you should be <40c idle.
Also, did you install the Ryzen chipset drivers and changed your power profile to "Ryzen Balanced"?
Stock cooler on tecware nexus Evo. All stock. Will go try the power profile though
shadey
It made a big difference in my clocks. Otherwise Windows does not know how to let the CPU downclock / idle correctly.
Philip
No diff for me regardless of the power profile. I hardly see my 3900X's vcore falling below 1V.
Phil
Philip
Not so idle temp with only Asus bloatware running.
10mins of AIDA stress test
Phil
Rashkae
Hmmm what's the flow setup - looks like it goes into the VRMs before the CPU block then the GPU?
kingsen
X570 Pro Carbon worth to get for 3700x ?
Sent from Samsung Galaxy Note 8 using GAGT
Philip
Doesn't really matter... the water temp will normalize eventually. Highest diff is 1c.
Pump -> Flow sensor -> Rad 1 -> Rad 2 -> Temp sensor 1 -> Rad 3 -> VRM -> CPU -> GPU -> Temp sensor 2 -> Pump
Phil
Hi guys, can anyone recommend me a graphics card for my R5 3600.
not a gamer. budget $200~300. maybe can drive a 4K monitor i may get in the future?
