Xiaomi Mi MIX 2S
TheSnail
I use Mi cloud. First backup to Mi cloud with old phone. At new phone, login Mi cloud and restore. For my case, home screen, icon position all remain the same as old phone. However 2 or 3 applications need to re install even icon appeared.
I use the Microsoft Launcher for exactly this same purpose......updating new phone to replace old.
NightRaven49
just asking around ah, got anybody try to ownself remove the back cover? i try myself like cannot leh, but i see online video like easy only. already use hairdryer warm up the back for 5 min, use suction cup but the glue sibei strong, cannot slip anything under to pry the cover.
also any recommendations for repair shop to help remove the cover?
carboy00
You need to replace something in the phone?
Posted from PCWX using Mi A2
NightRaven49
Removal of cover I am not too sure. $40 for battery replacement for Asus Zenfone 3.
I got a quotation of $20 labour charge, but I went to my nearby market got one shop quote $10 only. but still a bit high for my budget, so this week will try again, if still cannot then will go my market there do.
thanks for your recommendation.
ThinkMe
Posted from PCWX using Mi MIX 2S
ThinkMe
Wired as current Miui version is 11.0.4.0 with Android 9.
After upgrade, I have battery drain and WhatsApp delay problem.
Yeah, ever since MIUI 11, battery drain is significant..
cscs3
Xiaomi is lack of User Acceptance Test method. Saw forum there is people report issue with other areas after upgrade. I have issue of someone call but no ring tone intermittently.
NightRaven49
sic this 3800/4000/4300mah 3rd party battery for mix 2 and 2s. if feel like original battery dying, can replace with this one. currently using and definitely way better battery life, not say very ex also, about $10. only caution is that if buying the 4300mah battery, then maybe need to remove wireless charging coil to ensure fit.
https://item.taobao.com/item.htm?id=593440519790
weeza77
So 4000mah no issue?
