Redmi K30 Series, Pro and Ultra
cscs3
Yes but once the bootloader is unlocked, there would be problems of some mobile banking apps, SingPass Mobile, etc. right?
That's right. Xiaomi did warn you phone become unsafe once you unlocked your phone. And you cannot lock it back agian.
NightRaven49
you can lock it again, but it must be on the correct regional miui version, for example china set with china rom, no software modification. if u flashed global (poco) rom on china set k30 and try to lock, then it will hard brick.
Jurong640
Anyone can advise if Grab driver app can work on china rom? Tks
You need google play store and google mobile services (gms) for it to work. Not sure how to flash or install it. You might want to flash global from over.
But it is best you buy the SG local version.
j.o.i.d
Tks bro for the info. Really tempted to get the k30, if only it has global rom available, may have to look for nearby neighbouring country for it
NightRaven49
whats wrong with mi mi now? poco then now k confusing the entire world
they've been doing this rebranding of products for a while now.
eg.
mi 5x -> mi a1
mi 6x -> mi a2
redmi 6 pro -> mi a2 lite
cc9e -> mi a3
cc9 -> mi 9 lite
cc9 pro -> mi note 10
redmi k20/pro -> mi 9t/pro
Audiology93
My k30 until now not shipped. Seller told me to cancel my order...
Sent from Samsung SM-N950F using GAGT
amazingone
Redmi K30 Pro confirmed to come with Snapdragon 865
Computeron
the design like huawei mate 30 leh... like abit knock off..
but well, lets see how cheap.
