PC died ?
Jianwei Tan
ha. its private arrangement. tsk tsk;)
Haha.. anyway I bought seasonic s12ii 520w from lazada already.. have to wait them come and I'll update again.. if it solve other people might come across this post would have a better answer
limpingsim98
Use the GTX660 to power up the PC and quickly access the BIOS to set the default Display to Auto or iGPU.
If the power on duration is too short to perform the above, reset the BIOS should set the Display Options to Auto instead of PCIe (for discreet gfx card) for using the i3 6100 Intel® HD Graphics 530 iGPU.
Bios will auto fall back to onboard GPU if none on PCIe slot.
Jianwei Tan
Has a spare 500w power supply.
I already bought a psu le Haha
He don't have to come to your house. Just pass it to you downstairs or door step.
they all stay west or north .. I stay east cant trouble them come haha
update : pc able to start again with my old gpu after 12 hours rest.. but already bought a new psu from lazada. I'll update again if it's gtx 1070 problem
ystoh133
Your last statement confirm means PSU problem. You can read my long thread posted 1 month ago. My issues were far worse than yours.
jq75
works normal from there?
Jianwei Tan
i never go their house to test.. but if GPU got problem then die le.. dk my GPU still can rma not.. bought from carousell
i just saw! it seems very similar problem as mine. hopefully change PSU fixes it
Jianwei Tan
500w can buy at $50-60 , why need to buy 400w ?
you mean 2nd hand de ah.. first hand i see those platforms like lazada or qoo10 or shopee that is 500w all around 80-100+ , those less than 80 bucks de no hear before, scare later buy le fail again
Updated : seasonic s12ii came, exchange old psu with this new one, turn on got soft "****" sound and burning smell i immediately go force off pc then i try again an hour later , this time no smell le
but GTX 1070 not working so i tried switch to GTX 660, also no work.. but PCI-E connected to GTX 660 got LED lights up indicating got power feeding through it but not detected when i plug hdmi in
so i go download GPU-Z / CPU-Z / hwmonitor all only detect my onboard intel graphics, GPU not listed there
so i suspect the "****" sound burn the PCI-E off.. walao damn suay sia during ** so many problem here and there . now LL have to use onboard graphic and to do simple stuff
Edit : i tried plug in GTX 1070 and connect hdmi to onboard gpu and download nvidia gpu driver.. they say " graphics driver could not find compatible hardware " cannot install
was thinking for going ryzen 5 2600 with b450m motherboard , but fit in gtx 1070 with seasonic s12ii works not ah? or lack power
hafiz116
I would stay away from cheap PSU's. The pain of having to replace it and not having a working PC is just not worth it.
Jianwei Tan
previously i wouldn't care what brand is it.. as long as it has the wattage that i need, but now would buy well known brand
xtwis7
PSU is the most important component. Never scrimp on a good PSU so best to go for solid rated Brands that have high single rail ratings. Won’t go wrong with Corsair, Seasonic, Super Flower gold or even plat range.
jq75
Don't buy high end type. Least with proper true power psu that carries a warranty
'****' sound confirm something "fried"
Check carefully if I can detect what was burnt
Once I had so much difficulty that the burnt portion was on rear part of MB after stripping everything apart
On board graphic, can boot normal?
Jianwei Tan
thanks for reply! I wouldn't spend that much money on high end psu which doesnt make sense since I dont overclock cpu or GPU.
onboard gpu works can access to desktop just that gpu fan (gtx 660) not spinning .. even old gtx 660 that fan supposedly to run even just start pc which in this case isn't but got LED lights up on the PCB of the gpu
I've check visually nothing seems wrong no burn mark or anything on the motherboard nor the rear I/O .. everything works except no gpu detection
which leads to me that I need to get a new motherboard .. went online check the same new motherboard cost as much than getting ryzen2600+a320m motherboard from taobao which needed 100+ sgd more
edit : the pcie slot a bit hang downwards due to the weight of the gtx 660.. maybe that might cause the issue
jq75
If u adventurous enough, try on the GPUs u have
Clean the slots and contact pins. Sit them nicely into slot, try a couple of times b4 u declare it dead.
Electronics sometimes fail with no visible damage or whatsoever. It's just like "heng suay"
