SkyShroud
- Oct 28, 2005
Keyword: Flash memory
That is suggesting if flash memory is big, you can support all the cpu.
Any news for itx b550 boards... dont want to pay an arm or leg for x570 board
Yeah, the limitation with support is basically due to the BIOS ROM size. Sadly most motherboard makers uses 128Mb, while higher end ones will have 256Mb. With the release of the Ryzen 3xxx, there were already a lot of board struggling to support them and have to scale back on the BIOS GUI in order to accomodate the new CPU support. They are probably out of tricks now since it is a hardware limitation on older boards.
Based on the chart, it mentioned that the 500 series chipsets will support future Ryzen chips. However what they did not mention is that Ryzen 5xxx will not be using AM4 socket. In other words, you will be buying the B550 only for the current Ryzen 3xxx and the upcoming 4xxx series.
FroztSpectre, it does support 3000. Else why the release if X570 are for 3000.
I'm looking to build a gaming rig (1440p) that will last me around 4-5 years, I doubt I will upgrade the CPU but maybe the GPU if the GTX 30XX series are launched. So if I go with a Ryzen 3600 (max 3600X), which mobo series should I get to last me those 4-5 years as I will still be on the AM4 socket.
What I mean is that my future proofing is very unlikely a CPU upgrade, if there is a need I would rather change the mobo/cpu and probably almost everything.
So should I go for a B450, B550 or X570?
same predicament as you .... any advice guys? seems like a bad time to build a pc now with the rtx and cpu slated to launch this year
I was thinking of a "cheaper" x570 board. The upcoming MSI X570 MAG Tomahawk is suppose to be priced at 200 USD.
https://www.msi.com/Motherboard/MAG-X570-TOMAHAWK-WIFI
shiet! My gigabyte X570 have only 128Mb!
All the rest of X570 using 256Mb
gigabyte users can expect cut down bios...
