PC Rig Recommendations by MoneyFace =p
NightRaven49
Specs look pretty decent. Might want to check out the cheaper x570 motherboard as this will future-proof you a little (possibility of upgrading the CPU later and take advantage of PCIE 4.0 once prices drop) and bundle in the WiFi capability (Asus x570 TUF Gaming)
only got a handful of matx x570 though, otherwise need to look at other cases.
Steyr69
I deal with bizgram and they are operating online these days and insist on delivery option - no self collect. I just upgraded my wifi network to Ubiquity gear and got the stuff delivered to my home in a matter of hours :s22:
How much they charge for delivery?
Sent from Xiaomi MI A1 using GAGT
hafiz116
You can go for the B450 but just understand that there is a hard stop that is now real when it comes to the platform. If you're willing to accept that then it's all good.
I personally hate the idea of buying something that has a limit already in place so would avoid it. :s22:
Kel2505
Thanks Hafiz for your suggestions.
Was looking at b450 so that I still have the option to upgrade the processor to 3900 if needed.
Unlikely that I’ll need pcie 4.0 in the near future.
I’m also thinking if getting the gigabyte aorus pro WiFi will be a better option since it already has built-in WiFi.
hafiz116
As long as you understand the limitation going into this then its all good!
There are 2 things that limit you on the B450's. Gen 4 storage and PCIe 4.0 GPU's which are currently AMD GPU's. The upcoming RTX 3000 series GPU's will also be supporting PCIe 4.0 so even if your looking for the low to mid tier 3000 series you will not be able to use them on the B450 given its limitation of PCIe 3.0
So this is what I mean by future-proofing,....
Invazn
Thanks for the tip!
Lordzephyr9
which is the most reliable hdd now? WD black is almost twice the price of other brands.
Western Digital Black 7200RPM (5yrs) $292 4TB
Toshiba 7200RPM P300/X300 7200RPM(2yrs) $142 4TB
Given that 5700XT is having alot of issues, would getting 2060 super be a better choice?
Kel2505
Hi, for those that bought parts from amazon and Newegg, is the manufacturer warranty valid?
TLdomin
will need some advise on my current built. Will be very much appreciated!! :s12::s12:
Monitor: MSI MAG241C
Motherboard: MSI B450 Tomahawk max
CPU: AMD ryzen 3600
GPU: MSI RX 5700XT gaming X
RAM: G.skill trident neo z 16gb 3200mhz
Storage: Samsung 970 EVO Plus M.2 (256gb) / Samsung 860 EVO SSD (512gb)
PSU: Corsair RM 750
CPU cooler: Deepcool gammax gte rgb
PC case: Lian Li lancool 2
PC fan: 3x stock, 3x lian li bora digital
Total cost: $2400
Charlie_Zhan
CPU: AMD ryzen 3600
PSU: Corsair RM 750
Total cost: $2400
get a 1tb adata sx8200 pro locally or WD sn750 black via amazon instead.
for gpu consider the 2060 super or 2070 instead.
Kel2505
nope, usually theres no manufacturer warranty on parts only the 30 days thing
I see. Then is it worth the risk of buying without warranty? Are the prices there attractive enough to forgo the warranty?
Just exploring my options if I should check out from these sites too.
TLdomin
Hi Charlie_zhan, I tot for M.2 the Samsung one are usually the better ones compared to the rest? will kinda need your point of view for it as I am not very good at which storage device is better.
And for GPU wise despite RX 5700xt gaming X having some driver issue for some people but it can be resolved, for RX 5700XT gaming X performance is better then the RTX 2060 and can be on par with RTX 2070 but it also comes more affordable then RTX 2060 and RTX 2070. Why will you recommend RTX 2060/2070 more over RX 5700XT gaming X?
TLdomin
You can try platforms like Shopee, Lazada, Carousel and also from 'Bizgram daily DIY price' originally from Sim lim. sometimes newegg charge quite a high shipping price too.
i1magic
Which Thermal paste are you all using? Any good and cheap one from AliExpress?
Unic0rn
GeForce RTX 2080 Ti 11GB Team Green!
Kel2505
Thanks TLdomin.
Btw, anyone has recommendations for rgb casing fans?
Also, can ARGB fans still be used on non-ARGB motherboards?
Unic0rn
Thermal.take Riing Quad 14 RGB (3-Pack) Fans are quite value for money for 3 case fans!
You need 120mm or 140mm case fans?
