If you're thinking of buying a Secretlab chair... do NOT. Winter will come.
If anyone wants to buy a new Secretlab chair within these next 4 days (up to 23 May 2020), I have a very good discount code to pass on to you.
Only for serious buyer, please? Do not be selfish & let the discount code go to waste.
Any restrictions on which chair to get?
Sent from Rem Best Grill using GAGT
zensushi
Moderator
Moderator
I don't think so. You may have to try it to see if you can use it for your purchase.
I won't be using it...so would rather let someone benefit from it. :o
lunarsong
$70 off entire order? i thought referral is $25 off. u got cheat code is it :s13:
Jurong640
Just checking beside peeling, anyone has other issues? eg Lever, height adjuster, arm rest?
Nope. The chair is super solid, the cold cut memory foam is good. It's only the Prime PU 1.0 that is peeling. They are doing replacements for 1.0 users to 2.0.
zensushi
Moderator
Moderator
Same. Parts & structure feel as solid as day 1. :o
Jurong640
Yup, memory foam is the lumbar support pillow. Cold Cut foam not bad actually, don't see any deform of the shape unlike those cheaper chairs.
It's very sturdy built, the frame. Before I bought it more than 2-years ago, i worry about the lying to the back and will topple over. However, it proved wrong, it whole frame can withstand the weight, well designed so it won't topple. I felt they had done well enough for a gaming chair, for long term, but just that they need to improve on the PU Leather.
Swiftbladez
And the sad truth is that PU leather can never be improved beyond what the material is. :s13:
So don't care version 1.0, 2.0 20.0, pu leather is pu leather. I don't know how many times I've said it :s22: Secretlab isn't a research institution, they aren't going to create a brand new type of leather without the world knowing about it.
zensushi
Moderator
Moderator
Will this happen with the HM chairs or not? Wait for it...
https://twitter.com/MothershipSG/status/1262764739869859842?s=20
:s13: :s22:
jfreex98
They only know how to import oem product from china and than put secret lab logo on it...
