- Jul 14, 2005
safeentry soon
Hahaha no la. For wife. He sold alrdy
safeentry soon
This is super nice. How does it hold up? Any updates?![]()
Some photos of the UV tempered glass that I got from taobao. Installation is just like our WSD just that this one gotta align yourself since there's no frame whatsoever.
Surprisingly smooth since it's $21 for 2 pieces. Time will tell how it stands up but for now definitely better than the pre installed film![]()
Thanks bro.Still doing good! But I think it's not as scratch resistant as those atas glass like WSD. There's a scratch on the tg and I definitely didn't put it into my pocket with keys. I remembered it was scratched right after I put another phone on top of the glass.
So that's something to note haha
Thanks bro.
So when you applied the glue did not damage your receiver or buttons? Heard it's quite dangerousbit scared
Paste scotch tape over the buttons to protect them bro also the speaker grills
I see. I'll try, thx! The stock plastic sp is terrible when I'm not using a case. The edges re sharp as a knife
there's a stock plastic sp in the box...?
Thanks bro.
Happy to report that the A17 update recently released in Malaysia greatly enhanced night time camera performance.
The color is no longer dull and the unpleasant green cast is gone, too. Very happy with this update, hope it arrives in sg soon.(I manually updated)
Some before and after shots, and changelog
https://photos.app.goo.gl/xbPvQEZeWbEBYjAo6
Mind sharing link ? I went to oppo Msia web they are a15.
I'm currently at 75% with 2 hrs sot, so it seems comparable? Mi10pro is maybe 10% better?About 3 or 4 days of using the Mi10 pro. 90hz and even Always On Display on. 5h51m Screen On Time (SOT) with 30% battery remaining.
Believe if I turn off Always On Display even better battery.
This is without any optimizations like turning off background data etc.
20200529 mi10 pro SOT https://imgur.com/gallery/ow7ghRS
Yea oppo is impressive also. That said my mi10 pro genna hamtam by my Google photos syncing my photos nonstop today also.. Not sure if that had an effect.
Only down side for mi 10 pro China rom is some tweaking required to debloat etc. But v good phone otherwise
Hahah I can never get used to xiaomi's UI. They add like new features or improvements but since day 1 the UI has been largely similar
