Samsung Galaxy M21
Glariel
Think maybe I will buy this phone factory reset once and for all, delete and disable apps and do major tweaking in setting to give my phone a big battery boost in battery life. Keep the original firmware and don't update. My m30s I think I just throw away because this m30s phone I factory reset too many times until battery not so good.
throw away might as well sell to shop or give your family/friends/relatives
Pocoyoz
Lcd screen can reach sot 30h?
Sent from Amazon using GAGT
1982-1994
brief test from 62% - 23%
average on 4G starhub/ default cpu mode, every % in average:
browsing 13m
blasting music 8m*
streaming online 10m*
gaming 7m*
*the best I ever tested
if on performance mode, 10m for browsing
clock 311min SOT including gaming for don't know how long, average out 8mSOT/%
so if gaming fully on one full charge, can hit
11h SOT but of course on default mode, sure lag here and there, so if you game, this is not for you
I used Huawei 40W to charge, 1% takes 2m
if used the provided 18W,it takes 3hrs to fully charged though I know that it is not recommended not to use the default charger
about the 30h SOT, means 18mSOT/%, not possible judging on my non gaming and streaming usage...
sorry to hijack your thread
Angtehkor
browsing 13m
blasting music 8m*
gaming 7m*
This is about what phone and what 30 hours sot. Is it realme 6i
Angtehkor
So far no phone hit 30 hours on 4g usage on mix's activities such as browsing internet, blasting music, streaming video and etc. The best so far is 29 hours 10 minutes rooted Xiaomi mi max 2.
Angtehkor
This phone come out Singapore Liao. Cost between $290-$305 in shopee
Pocoyoz
https://www.gsmarena.com/samsung_galaxy_m21_hands_on-review-2121.php
However, the fingerprint sensor performance isn't as good as the one on the M31 and often takes a while to turn the screen on even when your finger is sitting on the sensor. The sensor itself isn't slow, as when the screen is already on the phone unlocks instantly but for some reason, the delay is much longer if the screen is off. The sensor is also flush with the back of the phone, which makes it difficult to zone into its position without looking at it.
All in all, we are not big fans of this fingerprint sensor and wish Samsung had used the one from the M31.
Unfortunately, the performance on the M21 isn't very good. Our review unit was the 4/64GB model, and that did seem to make a difference compared to the 6/128GB M31 we reviewed earlier this year. The M21 felt noticeably slower, especially during multitasking. Everything happens with a short pause and it's especially noticeable in the Camera app, which has a hefty shutter lag and then a further delay in saving the processed image.
Part of the blame also goes to the Exynos 9611 but we have seen this chip perform better in Samsung's other models, so this largely comes down to the memory configuration. We would strongly recommend you avoid the 4GB variant and go for the 6GB instead. But then the 6GB variant is too close to the M31 in pricing, so there's a bit of dilemma there.
Angtehkor
This phone in Singapore markup a lot Sia. But I not buying due to the stupid android 10 cannot read sot at all
Chao_Ah_Tiong
I can get this phone for free when I re-contract but don't think that I would like to get this phone as it simply means downgrading as I am currently using A7 (2018) and I'd prefer phones like A51 or A71 but too bad now Singtel is not offering that and most of the $0 phones are those China brands that I have no intention of getting.
Angtehkor
But this phone 6000mah battery leh. Very the big battery capacity. Can hit at least 5 hours sot with 80% battery left.
Chao_Ah_Tiong
Apart from high battery capacity and perhaps good enough camera, I don't see it any better than most A series.... There is no NFC, no USB OTG function etc...
Think I will see whether Singtel will re-stock A51 (I have called Singtel to enquire and they said that their A51 is out of stock) and offering it again or wait for the next A5X or A7X series. S and Note series are simply out of my budget and no way I am going to get a China brand phone nor downgrade to M21 or A11.
Pocoyoz
M51 Samsung 7kmah, 730g, amoled.
Buying anot?
