LoneTraveller
- Mar 31, 2012
1.Your second plan is actually workable with some changes, imho. I would shift your r2 to bedroom 3 and put it in either one of the green circles. This is to ensure maximum propagation of your wifi signals (5ghz) to all 3 bedrooms bedroom as the walls in the bedroom are mostly partition in new bto except for the black walls(solid wall).
2. Your db seems to be outside your flat? If true, then you might need a ap or router (acting as ap) at point 1 in your living room in case your r2 wireless is not powerful enough to reach the living room.
3. What I have done in my recent 5 room bto with a similar floor plan to yours (my db is in my flat) is to install a ceiling mounted unifi nano HD at the point marked x. It is enough to cover my whole flat with 5ghz signals(5 bars) so u might want to consider that.
