Redmi K30 Series, Pro and Ultra
ranmaru1987
Anyone feels that the vibration mode is super weak? I can't feel it at all when placed in my pocket. Anyway to adjust the intensity without rooting?
Posted from PCWX using Redmi K30 Pro Zoom Edition
On the contrary, I find the vibration quite strong..
Sent from Xiaomi REDMI K30 PRO using GAGT
Hardcor3Zoner
enable... cause when disable... some setting gone... keyboard also will change to sogo . one... but i guess mine is hardware issue... cause got reboot 2 or 3 times liaoz..
Oic, i disabled mine and apps seems to be working ok for me.
My KB will be changed to sogou only when i restart the fone.
However i encounter once when the fone auto reboot on MIUI 11 during my 1 mth+ usage til now.
Is there any setting for the fone to reset to factory using remote in case of fone crash and not able to turn on.
Cos if sent for repair will risk data leak?
Hardcor3Zoner
U can try using the diagnostics page and testing the vibration?
Can test out the various functions of the fone as well.
Press *#*#6484#*#* in calling screen.
Baroness
Tried it. Vibration is working. But really super weak. Left it on the table and it barely made a sound
hkchew03
That's because most budget phones cheap out on the vibration motor. It's even worse with a case on as most soft case will absorb some vibration
Posted from PCWX using Mi Note 10
ranmaru1987
Hmmm.. most reviews have reviewed that k30 pro vibration is flagship level.. I really find mine quite strong.. unless u have another set to compare it's hard to determine if yours is faulty..
Beefsteak
@frizee
you using default messaging app or what?
If not make sure you enable autostart and disable battery saver for the apps that you want to receive notifications.
For examples. Apps like google messages, wechat, line, whatsapp, facebook, banking apps etc etc.
frizee
@frizee
Hi bro, seems like everything is fine after I rebooted a few times. This MIUI is so cranky... Strange, I can’t locate ‘Autostart’ and MIUI Battery Saver’ option for the default SMS App though.
bladez87
Seems like my K30 pro missed the cut off..Zzz
K30 pro
Progress Indicator Status Date Location Activity
Future Event Delivery - -
Future Event Shipped - -
Current Event Label Created 06/27/2020 8:38 A.M. Hong Kong
K30
Delivery - -
Current Event In Transit 06/28/2020 2:26 A.M. Chek Lap Kok, Hong Kong
Past Event Shipped 06/28/2020 2:26 A.M. Chek Lap Kok, Hong Kong
Past Event Label Created 06/24/2020 7:09 P.M. Hong Kong
bladez87
same as your k30. export scan now. will be delivered by end of monday.
ya your pro maybe next flight liao.
Gg... Gotta wait 1 more week.
Can't believe I ordered this on 618 0003h and still can get delayed
What time and date was your label created?
The danger of keeping it there for 1 more week is that it might go missing...
Sent from Xiaomi MI 9T PRO using GAGT
MrRayded
Anyone using Gcam? which version and config do you use?
I'm using Urynx05's gcam without changing any config. The photo quality on the stock camera app is appalling and embarrassing given that it is a good sensor. Gcam takes much better photos
MrRayded
Just a heads up to everyone - China ROM will always have it's quirks and it's not meant for everybody like your less tech savvy relatives.
For example even until today I still face the issue of applications like telegram, carousel and Gmail not sending push notifications to my phone. Have to disable autostart and miui battery saver for notifications to be immediate. On my previous global ROM phones I never had this issue. Although for me at $470 vs $699 for poco F2 I can definitely live with it :)
Beefsteak
I think battery saving features is normal in every phone? Nothing to do with china rom or not. Unless the global rom don't have such features. I know my huawei phone with global rom also have battery saving features that somehow delays or disables the notifications and I had to change some settings or disable it for some apps.
MrRayded
Global ROM also has the battery saving features but I always receive my notifications instantly despite autostart off and using MIUI battery saver mode for my previous phones (Xiaomi Poco F1, Redmi note 5,Redmi note 4, mi5s). Even using YouTube vanced I don't need to disable battery saver mode for MicroG app unlike this K30 pro on China ROM..
Delaying or disabling notification is unacceptable just for the sake of battery saving, need to adjust the aggressiveness of battery saver. Imagine not receiving your telegram messages or emails on time!
