New HDB BTO Flat - How do you connect your Home Fiber Network
uncle_josh
ping test can ???
Oh and an extra note for new home owners of brand new BTOs lurking around: TEST EVERY SINGLE NETWORK POINT, PAY THE ELECTRICIAN OR SOMEONE TO TEST PROPERLY. Some unfortunate people in my cluster have dud/not working network points and the only solution offered is to run awful trunking all the way to the faulty/empty point. Flooring already done and they will not hack for you to lay the cables.
This kind of money don't try to save, test every single point make sure they are all connected to your db box.
Vulpix
Moderator
Moderator
ping test can ???
I saw devices used by the uncle to test both ends of network points, just test that it's working properly can liao. :s13: As long as it exists (not empty), at the very least it should work.
giraffey
Its called the cable tester. :) But not worth getting if just using it once. The other advantage is that it can also check for the quality of the connectivity.
hellgunner
A simple LAN Cable Tester only cost <$5. Why not worth it, even to use once?
Vulpix
Moderator
Moderator
Oh thanks! I saw the uncle using this atas looking Fluke one, I am guessing electrician have this item as a standard? He put one end at the dB box, the other end at the point he was testing. For sure it doesn't look like it's less than 5 bucks. :s13:
hellgunner
:s13:
Yup, the atas cable tester can easily cost thousands onwards.
If DIY check, get the simple tester to test connectivity.
Or hire professional that has atas cable tester, that can test connectivity & also test the connection speed.
Connectivity = To test that the 8 cables are connected correctly.
Speed = What speed you can expect of the installed cable can perform.
ahsiao80
If you have not purchase your google mesh.
1. Get a asus router that support AI MESH. And hook up another Asus AI mesh router in Room 2. Than you have 1 wireless network and 2 AP covering the whole house. This you can manage your router and wireless all under Asus UI.
2. If you already have a google mesh. You can try install google mesh in the DB BOX and see how the wifi speed and coverage before getting normal router to place in db box.
If coverage is good than no need to get another router. The google mesh in db box might give network wifi coverage to living Room, Bedroom 3 & kitchen. Node 2 will cover the rest of the house (MBR)
Was thanks everyone for your suggestion but this is getting bit too technical for my understanding haha.
Can anyone kind enough just advice me what should i do to gain the most coverage in my house? I currently do not have any ISP and bought the Google Nest Wifi yet :s12:
ahsiao80
I actually have a friend that did this setup.. i don't think its recommended right?
Vulpix
Moderator
Moderator
You mean you already bought your Google Nest?
ahsiao80
Why not recommended?
Almost everyone does it this way (just have proper shelf to sit on).
You just have to know, your is ONT or ONR.
What’s the difference between ONT or ONR? 🤔 isn’t this black thingy provided by all ISP?
Vulpix
Moderator
Moderator
haven bought it yet!
If you don't want to deal with too many technical things, getting a mesh setup would be the easiest, something similar to the Google Nest WiFi. Things like Ubiquiti require a bit of setup to get it working, but once it's up you rarely have to touch it.
ahsiao80
idm learning new things if everyone here is willing to guide me 😂
So this Ubiquiti is better than Google Nest IYO?
Vulpix
Moderator
Moderator
I recommend you search on YouTube how to setup unifi to get an idea. That will probably tell you if it's too much or just nice for you.
Guyver
i need to dig up the pic of my cabling for this home fibre setup inside the cabinet. you will be shocked . :p
sadboy
not easy to guide over a forums to setup.
Suggest you check out YouTube video to have an idea.
uncle_josh
ONT means you can use your powerful router
ONR mean your powerful router must be set to AP mode in order to use. All features of the powerful router will be rendered useless.
What&#146;s the difference between ONT or ONR? &#55358; isn&#146;t this black thingy provided by all ISP?
Sent from 天作孽 犹可恕 自作孽 不可活 using GAGT
