Redmi K30 Series, Pro and Ultra
xFidelity
K30 pro. Downloaded chrome from Play store. Chrome worked perfectly. Is your play store version same as me?
Sent from Xiaomi REDMI K30 PRO using GAGT
May i check if you needed to get any extra steps to get google play certified? I'm currently trying to get mine certified. are you able to use nfc for google pay? thanks 😁
ZhuTou!
Go setting, manage app
Delete data for playstore and google play service
Restart phone and it will be certified
xFidelity
I read it from the net
Not sure if it really works
No harm trying lol
Haha yeah that's actually one option I've not tried yet though so worth a try 😅
Btw, any idea how to get google pay working? I've tried google pay sg and google pay, and got prompted with this error "problem setting active account"
MrRayded
I found another incompatibility with Google apps in China ROM.
We are not able to enable location history for google maps for China ROM. Only way to fix it is to install a magisk module or flash global ROM which means unlocking bootloader
bladez87
yup. i noticed this as well.
cannot set location history because missing 1 background app.
bridgestonelk
Haha yeah that's actually one option I've not tried yet though so worth a try �
I have successfully setup Google pay Singapore and added cc. Tested the nfc payment, all ok.
What's your play store version and is your device certified?
xFidelity
Thanks bro, am currently on 20.9.10.
device still not certified and i tried registering by downloading
1. device ID app via playstore
https://play.google.com/store/apps/details?id=com.evozi.deviceid
2. copying my to register on the website provided on the article on xda
https://www.xda-developers.com/how-to-fix-device-not-certified-by-google-error/amp/
this google site
https://www.google.com/android/uncertified/
From link shared via bro nakedtoes, thanks btw 😁
bladez87
Anyone of you already unlocked and rooted your phone and installed the EU/Global ROM?
going to do it tmr.
i think as we start using the china rom, we might find certain google background apps missing and might hinder our usage.
so i thought better to just flash eu now and stick with it.
rather than using china rom, with all the latest china features but at the risk of breaking some google functionality.
see how some of the people in k20 pro/mi 9t pro thread complained that miui 12 disrupted some of their usage.
bridgestonelk
this google site
From link shared via bro nakedtoes, thanks btw �
My play store version is 20.6.19.
I downloaded the apk from previous post and there are for k30. Apprarently there are working fine.
Sent from Xiaomi MI 9 using GAGT
Beefsteak
going to do it tmr.
Thinking just want to unlock and install TWRP. And use Magisk hide.
But I heard that some banking apps like DBS etc and Singpass can still detect root even after magisk hide.
MrRayded
Got location history ma.. don't have meh?
Don't have, you go and check your timeline in google maps when you change to k30 pro all blank liao, tried to turn on but all cannot.
Sian, it's quite a useful feature
MrRayded
Ya, seems like missing 1 background app that's supposed to be preinstalled. Tried to sideload location history apk but still cannot work. Seems like a China ROM issue
xFidelity
Tried installing 20.6.19, it's still not certified though.
Also attempted to clear data on playstore app, does not work as well.
ranmaru1987
Mine got history leh..
