Redmi K30 Series, Pro and Ultra
ranmaru1987
How you install your Gapps? Is it just downloading the 3 APKs from the link in this forum?
Do you have more than one phone in use?
Just download the 3 apk.. by history u mean the locations u searched before right?
Sent from Xiaomi REDMI K30 PRO using GAGT
xFidelity
My play store version is 20.6.19.
I downloaded the apk from previous post and there are for k30. Apprarently there are working fine.
Sent from Xiaomi MI 9 using GAGT
Google pay works fine now, looks like all I needed was a factory reset and a fresh start 😁
ranmaru1987
Does this mean history works?
bladez87
if you have multiple devices with history on, they will show the same results.
u need to move around without the other devices...
thats how i intend to test.
bladez87
how you all check if your device is certified?
i flashed miui eu 12 rom liao.
ranmaru1987
I only move around with 1 device
ZhuTou!
Go playstore, setting, scroll to the bottom last
Will show below the playstore version
Posted from PCWX using Redmi 10X Pro
ranmaru1987
Wondering why you can enable google location history.
You didn't root right?
No leh.. all I did was manual update miui 12, then thereafter factory reset my phone and redownload all the 3 apks
xFidelity
Those apk u use all latest version?
Downloaded this set of apks shared by beefsteaks, thanks btw 😁
Indeed😂
Nice. Your life is complete.
