Prism+ TV
Audiology93
Anyone here who has a Prism + hooked up to a PS4 pro? Are you able to select the 4K settings on your console? For some reason mine is only going up to 1080p. The PS4 shows hdr not supported. I’m using a E43
Enable hdmi 2.0 on the TV.
Sent from Samsung SM-N950F using GAGT
ragudevan
Annoying part about this TV so far is... it sometimes power on and off by itself... not sure if the admin that can push the update also monitoring the TV and can remote the TV as well... creepy
Solved that for my 32" because of one of the settings
Home -> Settings -> Timer -> Change to off
I think also changed another option to off as well
chrisisx
Wow didnt know that there is too many issue with Prism TV. Good to know i read this before buying it. Will go for Xiaomi TV instead
andyhtc
Suspended
I'm currently using Prism+ E55. No issue so far. This is a very value for money TV.
nez
A friend of mine bought the E65, a 65" 4K Smart Digital TV.
Recently installed, so far he said ok. Did not check further. He told me his colleague had no issues with his so decided to take the plunge.
karchingkang
jialat.. the more i read frm this thread the more i sweat.. i tink i will ask for refund for my e65 if possible. Even now it is working doesn't mean after 1 wk/mth/yr will still work.
8-lane
What new tv are u gonna get in place of this e65?
karchingkang
i am thinking should i get Q60R than Q60T. Q60R has better refrsh rate that Q60T. Cheaper too from lazada. You tink is a good buy? 1.1k can get liao for Q60R. Price not far from Prism+
zplus
No Android OS and no Bluetooth? That's quite limited for a smart 4K TV. No Google play. You can't stream from your phone using Google or install new apps like Disney+ if they come online. I wonder if they keep their Netflix app updated too. Can't hook up Bluetooth devices.
sheshen
1.1k Samsung Q60R is 55inch. how come not far from Prism+ 55inch TV. It's almost double the price :s22:
pcuser123
Anybody using Xiaomi Mi TV Stick on Prism+ TV?
Any feedback?
Don't think we can get an answer here as Xiaomi MiTV stick is very new; also, PRISM TV running on LINUX is also new. The answer is whether there is a driver in PRISM TV..could not find answer also for Chromecast. Is there any PRISM people here to answer?
Expert
Can check with you guys... is there any issues with the 55" model now? Planning to get 1 for my dad. :o :s34:
