Samsung Galaxy Note 20 | Note 20 Ultra
Cryptology
Hahah. No mention of unlocked or not, or did i missed it? No galaxy buds live too right?
Historically HK sets got no prob here, even comes with the same 3 pin Uk plug. No galaxy buds but seller will throw in wireless charger
doki81
not going to get the set from SG.. might consider getting Note 10+ instead as need to get updated mobile plans.
yes..especially the buds live only value at $188...
mean at exynos 256gb still need $1710 ...
benqdell
For those out of luck for US, can try taobao for HK set apparently is also SD.
https://item.taobao.com/item.htm?spm=a230r.1.14.119.6f327d57kKs5zb&id=624972083922
Can go to the hk price website, price.com.hk and whatsapp the sellers. Most of them can help you arrange for shipping, just need to figure out how to pay them. Buy the 水货 since we don't need the warranty here anyway.
galaxyuser
All so desperate for SD note 20 ultra :yawn: :s13:
Ya lor. I can't be bothered. Got myself the Exshitnos 990 version cause cheaper via Singtel CIS. I'm all good with being short-changed, since I'm actually paying about 600 less via CIS.
doki81
aiya... not everyone has cis and phone bill sponsor by co...
Sent from Samsung Note 10 + using GAGT
kuma-mon
For those who bought note 20 ultra from US, do u guys check if the LTE bands can be used in SG? US uses CDMA while rest of the world use GSM, later buy liao then cannot use 4G. Not sure if Samsung manufacture the LTE chips differently by region.
rabbit1
You making it sound like everyone got top tier CIS discounts and handphone subsidy :s11::s11:
Xunnobi
Bhphotovideo shows that its compatible with our local telco =)
kuma-mon
Samsung kena exposed
S20 and note 20 series disable 120hz in QHD resolution because of exynos chipset. SD can run but they want to make it fair for both SD and exynos variant.
Posted from PCWX using SM-G986N
Glariel
I already suspect this
Was wondering why no limitations for Tab S7+ then why their flagship have limitations.
freshvibes
Samsung can just manufacture all sets with the SD variant but they choose not to. Really clueless as to why they have to do this.
Snoweagle
Same phone with different chipsets. Any other phone manufacturer actually does this?
SG has been using Exynos for their flagships for a while. Though it isn’t as good as SD but also not until so bad that’s it’s unusable. After using Exynos Note9 and current Note10+, it’s still quite ok.
But yes, Samsung could’ve used SD throughout and keep the price point which is more worth it.
rabbit1
I think got one year the SEA region used Exynos but Singapore was the odd one with Snapdragon.
doki81
already said before....the exynos is to create competition with sd chip so they can bring down the price for as..lower demand for sd mean lower price in future...but not fair for us :( they should price exynos set cheaper..then maybe will consider
